350 Engine Mods asking for advice!
Decide on how you want the end product to perfrom: Torque or HP.
For Torque, I suggest a tpi with alum heads with relatively small runners and a short duration cam such as a 268 or 272. Add headers with small primaries, 32" tubes, a 4-2-1- collector, 2.5" tubes with an X crossover and hi flo mufflers and you'll be a happy camper...... I like speed density with a chip from a reputable aftermarket chip burner. If possible, get a curve plot from a dyno, send the results to the chip burner and he can custom burn one for you.
I like tpi over aftermarket EFI since they are plentiful (read - cheap)and since the next owner of your Vette may not be able to tune it himself and may need to take it to GM for service.
if you don't want to spend all that $$$ on heads at this time, but have 'some' of the scheckels saved-up, are doing your own work, don't do too-much highway driving, and/or don't mind poor gas mileage, see if anybody makes 4.10 gears for your '63-'79 series-3 carrier:
you're already running 3.55s, so it won't be THAT much deeper gearing, your 'future' better-breathing heads will appreciate it, and at 6000 RPM, you'll top-out at around 110, but you'll get there MUCH quicker!!!!!
Better-flowing inlet (carb/intake/heads) and exhaust (heads/headers) won't matter much if the cam doesn't lift the valve off the seat much, and I'm figuring your stock '79 camshaft is something along the lines of:
.390" lift Intake/.401" lift Exhaust, with durations at .050" lift of 195* intake and 202* exhaust, respectively.
I'd think that a hydraulic cam with specs of approximately .420"-.450" lift, and duration at .050" lift in the .216*-.222* range (the old 327/350 HP L-79 "151" cam is very similar) would deliver a nice, torquey grunt, and a bit of a 'choppy' idle, perfect for cruising around town, without placing much stress on the valetrain, work well with your 3.55 gears and stock torque-converter, and deliver good performance, probably running mid/low 14-second 1/4-miles in the 94-97 MPH range.
Just my $.02-worth.....
Comp Cams magnum 270H cam (don't know if one I replaced was stock)
Dynomax Ceramic coat headers
MAD 2.5 inch chambered exhaust.
I had true duals through manifolds before the switch.
best 1/4 mile time on that setup was 15.0. According to the HP from ET calculator on smokemup.com that should be around 250-260 HP. Stock is 195.
The intake is still stock and so are the heads. From previous posts, most members agree those are now the choking points. Might need a little more compression too.
But I have other plans.. buhahahahaha!
The 308 gears & tall L-60s really sucked. When I tried a couple bracket races ( mostly to check ETs ) it would bog outta the hole till 3500rpm when it would come on the cam. At a 15 second dial in :o , I had a huge start to every car I ran but at 40mph two things happened! They pulled up beside me
& my motor would start pulling
to the surprise of a lot of BB cars that couldn't get away
to the tune of 107mph thru the traps
, but your gear choice with some other simple engine mods ( cam, carb, intake,timing, headers? & heads?) will do the trick
My '79 Z28 runs a flat-top, 64cc iron-headed 10.3:1 CR motor, CC 292H cam (.501" lift, 244* @ .050" duration), Victor Jr. intake, 750 dbl-pump Holley, 10" 'street' converter, 4.11 gears, and 26" x 8" sticky street-tires.
With open headers, shifting at 5800 RPM, on straight SUNOCO Ultra 94, it ran 13-teens @ 105 MPH in good air, usually 13.30s:
with an 8" converter and 28" x 10" Dragway Specials, it now runs 12-nineties @ 106 (best of 12.774 @ 109).
I drove this car to the track for 2 seasons, and still occasionally drive it around town (even with a spool...)
Hope this helps.....
I forgot to put my 2700 TC in my sig, but it's there now. My 79 seems to run pretty good for what it's got. I'm looking at either the vortec head package from Pace Performance for $795.00 or a few other heads from other vendors. I would like to get near the 12s....Perhaps the original poster can utilize the Pace Performance option...
First you have to determine whether you want mass air flow or speed density. The C3 is more conducive to speed-density due to space issues. Mass-air flow is easier to make engine changes without PROM changes. If you are technically proficient enough to make a Camaro harness work they can be bought for $100 or less. I have been told that you can also use a Cavailier harness with a little work, it uses the same ECM. Aftermarket harnesses range from about $300 for Painless to $500 for Howell to $700 for Street and Performance. Howell makes a great harness, but for a Tuned Port they do not make one that will control the converter lockup on a 200R4/700R4/4L60 transmission. If you are running a manual or non-overdrive-automatic transmission I highly recommend them. I have heard great things about Street and Performance harness, but do not have first hand experience with them. I also have a Fuel Injection Specialties (FIS) harness and it is OK. The ECM can be had used for $10-50. A good external fuel pump will cost at least $100. I use an 88 Ford Truck external pump, $114 from CarQuest, made in Texas by Airtech. If you have a 78-82 you can use your fuel tank with an 82 sending unit and a TPI pump. An aftermarket PROM with VATS and Emissions codes removed will be $100-200 depending on source and complexity. You will have to add an oxygen sensor to your exhaust, $20 for the sensor, $5 for the weld-in bung, and say $25 for an exhaust shop to weld it in if you can’t. Some harnesses use VSS and some do not. An auxiliary VSS sensor is around $75. To install a TPI I say figure at least $800 plus the TPI unit and whatever repairs are necessary to bring it up to useable status. I have TPI/700R4 in my 69 Corvette (Howell harness) and an 83 Pickup (FIS harness) and I love it. Starts good, great torque, good fuel mileage, easy to swap onto stock engines (although both of mine are out of 90/91 ‘Vettes).
Differences in years
All Corvette TPI intake manifolds work with the older (through 86) iron heads and the factory aluminum heads through 91. F-body TPI intakes use the upright center bolts on 87-92 and thus fit all 87-95 iron heads (non LT1). Either can be swapped to fit the other with some drilling. F-body has the fuel lines come out on the drivers side and has a central port for EGR. Corvette has fuel lines that come out on the passenger side and has an external port for EGR. Corvette fuel rails fit F-body intakes and vise-versa. The runners are all the same through the years, but the LH runner has a hole for a 9th injector in the 85-88 runners. This can be plugged off if you get a nice LH runner and don’t want the 9th injector or decide to run speed-density. The plenums all physically interchange, but 90-92 have an extra vacuum port for the MAP sensor used with the speed-density computers and wiring. 89 is an odd year, it is mass-air flow but without the 9th injector. 89 up throttle bodies can be used on all years, but a 85-88 throttle body requires a ½” hole be drilled in the front of a 89-92 Plenum for idle air. 89-92 Throttle bodies have a bit more desirable cable attachment. The cable attaches around a circular linkage which has a smoother actuation than the straight linkage on the 85-88. The Corvettes have an aluminum plenum extension over the distributor, the F-body extensions are plastic. The Corvettes use an HEI coil-in-cap distributor for 85-91 (Delco 1103680). 85-86 F-body also used a big-cap distributor. 87-92 F-Body used a small cap distributor with an external coil (Delco 1103479). This same distributor is used in the 87-95 5.0/5.7/7.4 TBI injected trucks. The F-body intake gets it's exhaust for EGR from the center passages in the heads like most SB Chevys. A Corvette intake gets it's EGR exhaust from the RH exhaust manifold/header through a flex-tube to an opening near the distributor-no center passages in the intake. If you are required to keep EGR and you have a Corvette intake, I recommend geting the C4 exhaust manifolds. They are like mini-headers, and have a 2 1/2" outlet. I have them on my 69 and like them.
As far as a throttle cable to use, on my Vette, I used a TPI Corvette cable, 1990 I think (about $20 new GM) but you have to cut the end off inside the car and use a hood-release-cable end (Corvette Central 342138 "cable stop") to get it the correct cable length (the housing is OK). You must use a cable from the type car your throttle body came from if you want to have a chance of not cutting it. Again, 85-88 use a straight pull, while 89-92 have a circular attachment for more smooth actuation and so the inner cable is longer. On my 83 truck I used a TPI F-Body cable and it was OK, but I had to coil it up into a loop in the engine compartment because the housing was so long. I also TPI'd a 72 Chevy truck and used a 90 350 TBI truck cable for it. It was 1/2" short outside if anything, but I was pretty pleased with it all told-I didn't have to shorten it. In a Vette it might be about right. In all vehicles I've done you need a die grinder to square the firewall hole off a bit. All vehicles I've done used the late throttle-body.
Why to get it
If all you want is around 300 hp there is no reason to spend a pile of money on a crate motor. The basic $1200 4-bolt Goodwrench 350 with an aluminum intake and a Holley will put out power in that neighborhood. Chevy High Performance (I think) did a series of articles with one of those a few years back and with decent exhaust should get you in that range.
I would look into a TPI. They start immediately in winter, have great vacuum, and will get great mileage. I can open the headlights and the wiper door at the same time with no hesitation at all-solid wooomp. With 3.70 gears (and a 700R4 overdrive) I get 18mpg city and 22+ highway. With 3.55 or 3.36 it would be even better. You can probably find a used Corvette TPI engine for $1000 and with an $800 harness/computer/fuel pump you would be set. On a 78-82 you can use the stock fuel tank with an 82 sending unit and TPI pump and be in better shape than 68-77 with an external pump. With the Vette TPI you would have aluminum heads that would remove weight. Even with an F-body iron-head TPI 350 it will be less weight than a stock intake. It will bolt up to everything in your car, use stock accessories, use your transmission, and the visual appeal is awesome. Don't be afraid of fuel injection, it really works.
As far as websites see:
www.corvettefaq.com for conversions or more TPI info at www.fuelinjection.com
this is my upgrade that i will tie to a 700r4 3.08 rear and steeroids. i pick up engine tomorrow and post as i go
http://forums.corvetteforum.com/showthread.php?t=959450
