C3 Trivia-Engine/Transmission Options
Old Nov 29, 2004 | 08:11 PM
  #41
Double Aught's Avatar
Double Aught
Originally Posted by paul67
Why is the 1977 Corvette unique?
One year only for Corvette Chartruese paint. One ordered.
Old Nov 29, 2004 | 08:14 PM
  #42
Paul L's Avatar
Paul L
No Where,
Not sure where I went wrong but here is reality.
Old Nov 29, 2004 | 08:16 PM
  #43
Twin_Turbo's Avatar
Twin_Turbo
77 has mix interior, early style dash cluster & new style console for use w/ standard radio ???
Old Nov 29, 2004 | 08:21 PM
  #44
Paul L's Avatar
Paul L
Double Aught,
You are absolutely correct. I was thinking of the demise of the big block engine and the convertible.
Old Nov 29, 2004 | 08:25 PM
  #45
Paul L's Avatar
Paul L
TT,
It had the late style dash and early style interior.
Old Nov 29, 2004 | 08:29 PM
  #46
lostpatrolman's Avatar
lostpatrolman
Originally Posted by Twin_Turbo
What was different on the 82 FE7 suspension from all other years.
wasnt it a 7 leaf spring or something?
Old Nov 29, 2004 | 08:31 PM
  #47
Twin_Turbo's Avatar
Twin_Turbo
no something else
Paul, 77 had the old style dash w/ old style speedo/tach cluster, the center console/shifter plate/parking brake cover was the only new style section about it for use w/ standard radio.
Old Nov 29, 2004 | 08:34 PM
  #48
Paul L's Avatar
Paul L
Last trivia post for this evening. Wish I could afford one of these. A 1969 convertible. My favourite C3 year. Hope to own one some day. What is the difference between an L36, L68, and an L71. Needless to say I will not get into the L88 mess.
Old Nov 29, 2004 | 08:36 PM
  #49
Steve's74's Avatar
Steve's74
Originally Posted by 80Xflags
I think they physically cut out part of the fiberglass in the wheel well. Don't remember where or which part.
Yup, they cut off the inner lip of the front wheel wells. I was a Chevrolet service manager back then and still remember the shock we all experienced when the first one came in. Looked like something done in a back alley shop somewhere.
Steve
Old Nov 29, 2004 | 08:42 PM
  #50
Paul L's Avatar
Paul L
Steve,
Yes the factory did that trim to accommodate those 255s. I had pics of my 1979 cut factory fender lips but they were lost when my last computer collapsed. So sad to lose memory.
Old Nov 29, 2004 | 08:56 PM
  #51
Paul L's Avatar
Paul L
lostpatrolman,
It was the width of the spring. TT will recall my memory re C3s but I believe the narrower FE7 spring carried on into the late C3s with the front 1/ 1/8" and 7/16" rear sway bars. That was the ideal combination according to GM engineers. I don't have my C3 reference books any longer to confirm that. Sorry!
Old Nov 29, 2004 | 09:20 PM
  #52
early shark's Avatar
early shark
Paul:
L-36 is 390hp, 427cid, oval port aluminum manifold, Rochester 4bbl, 3/8ths pushrod, cast aluminum pistons, cast iron crank, 2 bolt main block, 10:25 comp ratio. L-68 same as above, except Holley 3x2bbl carb set-up on aluminum manifold. 400hp, 427cid. L-71 is 435hp, 427cid, square port aluminum manifold, Holley 3x2 carb set-up, 7/16's pushrod, forged aluminum pistons, forged, nitrided, chamfered crank, 4 bolt main block, square port heads, 11:00 comp ratio.
Old Nov 29, 2004 | 09:37 PM
  #53
comp's Avatar
comp
A 1983 Corvette was developed in 1982 but was not introduced until until 1984. Why?
Q/C and production line change i think
Old Nov 29, 2004 | 09:55 PM
  #54
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Dear to my heart....What was the rarest engine/transmission combo in the 1967 Corvette? Not the most desired by any means.
L88 4 speed. to get the L88 option you were requreied to get F41, J50, J56, K66, and M22 so there 20 were made like that meaning most rare in 67
Old Nov 29, 2004 | 10:32 PM
  #55
oregonsharkman's Avatar
oregonsharkman
What major changes occurred in the 1975 model year? There are three at the minimum.
no convertible, no big block, annnndddd.....?? aluminum wheels??
Old Nov 29, 2004 | 10:44 PM
  #56
oregonsharkman
AHHH maybe I should read the rest of the posts before I answer----------(already answered)
Old Nov 30, 2004 | 01:14 PM
  #57
SLVRSHRK's Avatar
SLVRSHRK
In 1981 what option provided for an oil temp gauge?
Was it the radio option that included the digital tuner/clock?
To C3 Trivia-Engine/Transmission Options
Old Nov 30, 2004 | 01:18 PM
  #58
Paul L's Avatar
Paul L
Yes. When the clock was moved from the gage cluster to the radio, an oil temp gage replaced it.
Old Nov 30, 2004 | 01:34 PM
  #59
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
No it was not, that system, like the 81 L81 is CCCC which stands for computer controlled catalytic converter, they are not the same.
Actually I think you are both wrong.
The 1980 L-G4 was the first to have computer controls. The computer controlled the timing advance and mixture for the primary side of the carburetor. This was only on the 305 CI engines for sale in California, and from what I understand some of these were also sold in areas of high altitude.
1981 had the same computer in all Vettes. CCC is computer-command-control. I have never seen or heard of CCCC or any type of computer controlling a converter as it is a chemical process that does not require electricity.
1982 was the first computer controlled fuel injection, with the twin TBI unit Cross Fire injection. Not to be confused with the first gasoline fuel injection, which was the 1957 Corvette with the Rochester mechanical fuel injection.
Old Nov 30, 2004 | 02:16 PM
  #60
Twin_Turbo's Avatar
Twin_Turbo
it's not controlling the converter but the oxygen flow, that's what makes it a regulated converter. The air switch valves take care of that.
