C3 Trivia-Engine/Transmission Options
Old Nov 30, 2004 | 06:45 PM
  #61
Marks69BB's Avatar
Marks69BB
What option was a 69-only option that was a carry-over from the C2's?
What other external trim option was a 69-only option?
When were fiber optics introduced and what year did they dissappear?
When was the removeable rear window dropped?
Other than 77 and up, what other years did the stingray or sting ray nameplate not appear on vettes beginning with 63's?
Other than the Zl-1, what is the next rarest 69 engine option (not what you might think)?
Old Nov 30, 2004 | 06:59 PM
  #62
Paul L's Avatar
Paul L
I would say the Holley.
Old Nov 30, 2004 | 07:04 PM
  #63
Paul L's Avatar
Paul L
RPO TJ2 Front Fender Louver Trim.
Old Nov 30, 2004 | 07:06 PM
  #64
Paul L's Avatar
Paul L
There was no 1968 Sting Ray.
Old Nov 30, 2004 | 07:10 PM
  #65
Paul L's Avatar
Paul L
Other than the L-88 I do not know!
Old Nov 30, 2004 | 07:16 PM
  #66
early shark's Avatar
early shark
fiber optics feature was standard on '68 thru '71 corvettes.
rear window feature standard on all 1968 thru 1972 corvette coupes.
Old Nov 30, 2004 | 07:21 PM
  #67
75 Stingray!'s Avatar
75 Stingray!
Originally Posted by 80Xflags
I'm guessing 1975 b/c of catallitic converter heat?
Nop
http://forums.corvetteforum.com/showthread.php?t=957544
Old Nov 30, 2004 | 07:28 PM
  #68
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
1. What option was a 69-only option that was a carry-over from the C2's?
2. What other external trim option was a 69-only option?
3. When were fiber optics introduced and what year did they dissappear?
4. When was the removeable rear window dropped?
5. Other than 77 and up, what other years did the stingray or sting ray nameplate not appear on vettes beginning with 63's?
6. Other than the Zl-1, what is the next rarest 69 engine option (not what you might think)?
1. side exhaust
2. TJ2 Front fender Louver Trim
3. 68-71
4. 72
5. 68
6. 350/300?
Old Nov 30, 2004 | 09:41 PM
  #69
A C's Avatar
A C
Cruise-In II Veteran
1. side exhaust
3. 68-71
4. 72
5. 68
6. 350/300?
6. Supposedly there were 2 LT-1 Vettes in 69. I know one of them was dealer installed for sure. The other may have been a factory test mule. In the 69 AIM it shows the LT-1 stripe placement diagram. That would have been a neat car...69 LT-1 with sidepipes!
Old Dec 1, 2004 | 12:34 AM
  #70
Marks69BB's Avatar
Marks69BB
1. side exhaust
3. 68-71
4. 72
5. 68
6. 350/300?
All correct except 6.
The answer to #6 is the L89 option (L71 with aluminum heads) which was ~20, fewer than the legendary L88 which was 169 vettes in 1969.
Old Dec 1, 2004 | 12:38 AM
  #71
Marks69BB's Avatar
Marks69BB
I'm not sure because I've never heard of or seen one. Is that one you mentioned documented? The L89s are definitely the next rarest since there are many verified examples.
Old Dec 1, 2004 | 12:46 AM
  #72
Marks69BB's Avatar
Marks69BB
Paul - When I wrote this question I was thinking that the 67s did not have the Sting Ray emblems either because when you hear about them people say they were devoid of emblems that were on the earlier C2s. I'm assuming from your answer that I am wrong?
Old Dec 1, 2004 | 12:49 AM
  #73
A C's Avatar
A C
Yep, the dealer installed LT-1 is in the 69 Stingray Guidebook. It has pictures with the stock 69 small block hood.
Old Dec 1, 2004 | 01:05 PM
  #74
early shark
The L89 option was 390 units in 1969. The L88 engine was 116 units, broken down as 99 manuals and 17 automatics. The 101 M22's were distributed to the 99 L88's and the 2 ZL1's.
My guess would also have to be the supposedly 1 built '69 LT-1, as to what is rarer than the ZL-1 engine in 1969.
Old Dec 1, 2004 | 01:20 PM
  #75
Paul L's Avatar
Paul L
This is a 1979 L-82 intake. Note the thermal vacuum switches (TVSs) for the EFE and EGR systems on the thermostat housing and intake respectively. Some C3s of that era had a second TVS on the thermostat housing. In fact you can see the cast/plugged boss where some housings were threaded. What was the purpose/function of that third TVS? I do not know the answer to the question but have always been curious.
