4 speed Trans question
Old Nov 30, 2004 | 12:51 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Default 4 speed Trans question
The 4 speed in my Vett has 2 rings around the input shaft, any idea what it is?
Old Nov 30, 2004 | 01:02 PM
30cal's Avatar
30cal
M20.
http://www.5speeds.com/muncie2.htm
Old Nov 30, 2004 | 01:05 PM
norvalwilhelm's Avatar
norvalwilhelm
The lowest of the 4 speed. Wide ratio. The best has no rings but a drain plug. One ring no drain plug a close ratio 2.2 first, middle of the line.
2 rings, 2.5something 1st gear and wide ratio
This is only from an old memory but close.
Old Nov 30, 2004 | 01:06 PM
wacked's Avatar
wacked
Thanks for the link
To 4 speed Trans question
