need help diagnosing instrument gauge
Does anyone out there with an oil temp gauge know which color resistor is suppose to be on the back side of the gauge? If you look at the back side of the instrument cluster, you will see different color resistors on each of the gauges. My oil temp gauge has a green resistor. I'm wondering if this is the correct resistor for the gauge.
definitely over myhead but heres some thoughts....doesn't the resistance change in the sending unit based on temp and that translate in to a reaction in the gauge, how do you know the sending unit is good? how did you ground the sending unit when you put it in the water for your test?
The gauge gets the 12V in but the ground is through the sending unit. Have someone watch the gauge with the key on and see if grounding out the sender wire at the block causes the gauge to peg back and forth as you ground the wire. If it does, the wiring is fine and the gauge is working right. The sender can be tested in a hot water off the car or on the car. Check the resistance with an Ohm meter between the threads and the wire connector. The resistance will vary over different temperatures. I do not know what the exact resistance will be for you but around 500 Ohms at room temp and maybe only 100 Ohms at boiling would be a possible scenario.
Hope this helps.
-Mark.
Hope this helps.
-Mark.
The gauge does peg when the sender wire is grounded. I did check the ohms, and it did drop when placed in hot water but my values were a lot lower than what you specified. I think at room temp it is around 3 and droped to around .8 when placed in hot water.
