Lowering Megaladon
Old Dec 7, 2004 | 01:49 PM
hosspowerinc's Avatar
hosspowerinc
Maybe I can help. By cutting 1/2 a coil off a spring you increase its rate by 10%. Thats right. Increase. Cutting 1 coil makes it 20% and so on. Ever notice aftermarket lowering springs? They are shorter with less coils. Factory are taller with more coils. You can increase or decrease rates by the thickness of the wire, diameter of the coils, and number of coils. The "softness" in your ride is all mental as it is really stiffer. Hope this helps. Justin
Old Dec 7, 2004 | 03:32 PM
Turbo-Jet's Avatar
Turbo-Jet
Originally Posted by Gordonm
Grade 5 is good but a Grade 8 is better. Stick with a Grade 8 you would hate to have a failure due to a weak bolt.
min proof strength SAE:
grade 5: 85 ksi
grade 8: 120 ksi
1/2-20 has tensile area of .1599 in^2
so proof load is:
grade 5: 13600 lbf
grade 8: 19200 lbf
I’d estimate the load fluctuates between 1000-2000 lbs
fatigue is not of too much concern as the load is always in tension. (reversing loads are the worst ie alternating tension-compression as in bending)
for comparison, when you torque your connecting rod bolts (3/8-24 x 2” ??),
stretching them .0065” results in 8500 lb of force
Old Dec 7, 2004 | 10:21 PM
Turbo-Jet's Avatar
Turbo-Jet
here is a handy formula (for linear rate springs)
everyone knows Hooke's law F=Ky
F=force applied
K=spring constant, rate
y=deflection
using Castigliano’s theorem of strain energy
(insert arm-waving here)
K=G*d^4/(8*N*D^3)
G=modulus of rigidity (carbon steel= 11.5E6 psi)
d=wire diameter
N=number of active coils
D=mean diameter of helix
Everything else is constant so as you can see, if N decreases, K will increase
Hence cutting out coils increases the spring rate
Old Dec 7, 2004 | 10:44 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Now I have a headache.
Old Dec 7, 2004 | 10:51 PM
hosspowerinc
F=force applied
y=deflection
K=G*d^4/(8*N*D^3)
d=wire diameter
Hey thanks. I was looking for that formula but I miss placed the book. Justin
Old Dec 8, 2004 | 03:19 PM
vettery's Avatar
vettery
"Very confused here... they shouldn't get stiffer ...???... you reduce the pre-stress when you install the shortened spring."
Originally Posted by 69autoXr
I'm not familiar with pre-stress. Is it a material property?
The amount a spring compresses when installed depends on the weight it must support and the spring's rate (lbs/inch).
Shorten the spring (reduce the number of active coils) and the spring's rate will increase (more lbs/inch).
The shortened spring will have to compress less to support the same weight.
Old Dec 8, 2004 | 05:28 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
By 'pre-stress' I meant the amount by that the spring is compressed when installed between the upper and lower pocket.
The uncut spring is compressed by a decent amount - I'm guessing roundabout 3" when installed. After cutting one coil off the spring is only compressed 1-1/2" when installed.
Then, when you get the car off the jacks the spring compresses even more when supporting the car's weight.
I agree with the posts above, the formula is correct, but I am 100% sure the front feels softer than before cutting the spring.
Maybe VBP has an answer to this ???
Old Dec 8, 2004 | 10:12 PM
Lotus76's Avatar
Lotus76
FYI,
VBP told me that cutting off 1/3 coil = 1 inch lowering. He may have been referring to the 550 springs.
