Lowering Megaladon
Old Dec 6, 2004 | 05:35 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Default Lowering Megaladon
If i wanted to lower the front end 1 to 1 1/2 inches,
how much spring would need to be cut? I was gonna start
with half a coil end.
Old Dec 6, 2004 | 05:57 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
There's a similar thread:
http://forums.corvetteforum.com/showthread.php?t=963361
I copied my reply:
I cut my front 460lbs springs for the same reason - it was sitting too high. The front suspension was great before I cut the springs ( I cut 3/4 coil ) - now it is a little too soft for me and I'll very likely buy the 550lbs springs soon.... these are supposed to lower the front 1" without cutting.
For the rear I bought the 8" bolts for $19.99 at Ecklers, I could not find any bolts longer than 6" at the local hardware stores so I had to spend the $20.... pretty expensive for two silly bolts.... at www.mcmastercarr.com you can get these for $4 a piece (Grade 8, 1/2" thread, 8" or 10" long)... but they overcharge on shipping...
Old Dec 6, 2004 | 06:07 PM
Schmucker's Avatar
Schmucker
What is the size of the bolt for the rear, I'll see if my mom carries it at her hardware store.
Old Dec 6, 2004 | 06:17 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Take the original with you, 8" grade five.
Old Dec 6, 2004 | 06:19 PM
LFZ's Avatar
LFZ
I'm not a bolt person by any means..but isn't grade eight recommended and sold by VBP and others. I think its stronger.
Old Dec 6, 2004 | 06:33 PM
Retro78's Avatar
Retro78
These bolts need to have the proper stength. I doubt a hardware store carries them. I purchased mine from a local specialty fastener shop, they were not any cheaper than buying from one of the corvette vendors. A failure would be very bad.
Old Dec 6, 2004 | 06:35 PM
Cali,68,L-79
You may be right. I bought mine with cushions from VDB.
Old Dec 6, 2004 | 06:50 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
As I said, if you add the shipping then you'll end up at $20 anyway.... It must be Grade 8, the hardware stores have cheap quality bolts in 8" for $1.99 - don't buy these !
Old Dec 6, 2004 | 06:51 PM
Gordonm's Avatar
Gordonm
Grade 5 is good but a Grade 8 is better. Stick with a Grade 8 you would hate to have a failure due to a weak bolt.
Old Dec 6, 2004 | 07:32 PM
69autoXr's Avatar
69autoXr
This is interesting, because springs are supposed to get stiffer when they're cut. Definitely mine are stiffer since I cut them. Did you cut from the top or the bottom?
My car was still sitting too high even with the 550's. I cut a half coil and got nearly a 1 1/4" drop! It was actually the perfect amount, and put the car right where I wanted it, but I wasn't expecting so much drop out of only a half coil.
Old Dec 6, 2004 | 07:43 PM
MEGALADON's Avatar
MEGALADON
I forgot to say this is the original front springs, but not worn out.
Should it be wise to start off with a 1/4 cut.
Old Dec 6, 2004 | 08:28 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Very confused here... they shouldn't get stiffer ...???... you reduce the pre-stress when you install the shortened spring.
I cut 3/4coil and installed the spring so the cut was at the top, this made terrible noises .... I took them out again and installed them so that the cut was at the bottom, now it's fine... just a little bit too soft for my taste... I guess I'm too lazy to do this spring excercize a fourth time ... maybe I buy them when they're on sale for $59 again - now, after your input I'm not sure anymore if I should cut those or not...
Old Dec 6, 2004 | 08:29 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I went down to the weeds, about a coil and the bump steer is pretty bad. Go 1/2 and wait until the next day. It will settle about a 1".
Why is your car hidding behind a tree?
Old Dec 6, 2004 | 08:32 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Just cut 1/2 or 3/4 coil and see how you like it - that should lower it by 1" or 1 1/2"
Use anti seize and don't torque the bolts too much just in case you don't like it and want to install different springs...
My guess is that it lowers the front but will be way too soft.... front 550lbs springs are inexpensive, why even bother cutting the stock springs ?
Old Dec 6, 2004 | 08:40 PM
Cali,68,L-79
my 68's coils were cut 1.5 coils and dropped from 27.4" to 26" and I have 27.4" in the rear with VDB 8" bolts.
Old Dec 7, 2004 | 11:44 AM
MEGALADON's Avatar
MEGALADON
it's kinda shy
Old Dec 7, 2004 | 12:10 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
3/4 coil, cut from the bottom. Smaller coil spacing in the coils go up. Make sure spring is seated in the upper pocket.
To Lowering Megaladon
Old Dec 7, 2004 | 12:16 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
cut one coil out of vb&p's 460lb spring..
went from this
to
Old Dec 7, 2004 | 12:58 PM
Cali,68,L-79
[QUOTE=Corz]cut one coil out of vb&p's 460lb spring..
went from this
WoW!!! Nice 4x4!! Looks good I'd still chop another 1/2" clearance. Mine's at 26"
Old Dec 7, 2004 | 01:04 PM
69autoXr's Avatar
69autoXr
I'm not familiar with pre-stress. Is it a material property?
