Harmonic balancer question
Old Dec 7, 2004 | 12:32 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Harmonic balancer question
I'm pretty sure mine is getting sloppy. So looking in the Summit catalog I see a number of choices.
1-Is a piece like the Rattler worth the $$ asked?
2-Should I get the same diameter or does it make a difference?
3-When installing, I'm guessing/thinking to measure the crank hole diameter on the old one and bore or hone the new one to the same size, right?
Old Dec 7, 2004 | 12:40 PM
Fevre's Avatar
Fevre
1. Prolly not for street use
2. Bigger is better in this case but make sure it will work with your other parts (water pump, timing tab, etc)
3. NO! They are press fit so get an installer tool to do it right, can be loaned from autozone.
BTW Make sure you get the right one as far as int vs ext balancing. I actually have an 8" balancer with a removable weight that can used for either int or ext balanced engines.
Old Dec 7, 2004 | 12:53 PM
AlwaysWave's Avatar
AlwaysWave
Fevre, I know they're press fit, that's why I thought of duplicating the inside diameter of old to new. Not right thinking?
The engine is a base model crate I bought from Scroggin Dickey. I'll contact them about how it's balanced.
Old Dec 7, 2004 | 12:56 PM
zwede's Avatar
zwede
The aftermarket balancers pretty much all need to be honed to fit. The instructions give you some pointers. I got an ATI and just honed it until I could get it installed (using the correct tool). As delivered they are too tight to install and can damage the crank if you force it on.
Old Dec 7, 2004 | 02:04 PM
hosspowerinc's Avatar
hosspowerinc
Stick with the factory unless you have a high performance motor. That race stuff is just that. Race stuff. Its only good if you are reving over 7000rpm. You know the factory one will fit and wont cause any problems. And best yet its cheaper. And bigger isnt better. More rotating weight eats power. Just stick with a replacement. Justin
Old Dec 7, 2004 | 02:20 PM
zwede's Avatar
zwede
Problem I had was that most of the replacements are made in China, and I don't trust a made in China @ 6000 rpm. The genuine GM replacement is probably good but costs almost as much as an ATI/Fuidamper etc.
Old Dec 7, 2004 | 03:43 PM
Marv's Avatar
Marv
You could also check with damper dudes at harmonicbalancers.com for rebuilding yours. They quoted me $85 for an 8 inch GM balancer. Another rebuilder is damperdoctor.com-they are across town from each other in/near Redding CA.
Old Dec 7, 2004 | 10:10 PM
C8H18's Avatar
C8H18
Marv, thanks for the links - never considered this route.
ATI also has one called StreetDampr - thats the one I was leaning towards, it's relatively inexpensive and comes w/ degree marks.
Old Dec 7, 2004 | 11:46 PM
Glassbowtie77's Avatar
Glassbowtie77
I just bought a brand new 6-3/4" Harmonic Balancer on Ebay for $39.95 including shipping. It is made by Silver Seal Products in Trenton, Michigan 1-800-521-2936. It is an exact duplicate of the original factory unit that I removed and is a very nicely made piece. Installation was a piece of cake, just make sure you use an installation tool to put it on, DO NOT hammer it on!!
Old Dec 8, 2004 | 12:28 AM
zwede's Avatar
zwede
Sorry, but for $39.95 I bet it's China made. There's a lot of shady labeling going on in the auto parts industry. For instance, the part can be made in China, and then a US company drills and taps the holes for the pulley and it suddenly becomes "Made in USA". Unfortunately this relabeling is legal.
Old Dec 8, 2004 | 12:33 AM
FEDX's Avatar
FEDX
From: A high school diploma fixing what a college degree broke TN
Where is the Rattler made,and does anyone have any experience with running one?
Old Dec 8, 2004 | 08:07 AM
pws69's Avatar
pws69
Has anyone used a balancer from CNC-Motorsports? I am considering this one for my 69 350 -
PP-80002
SB Chevy 350 Powerforce 8" Street Balancer - Internal Balance - $ 53.00
Old Dec 8, 2004 | 08:48 AM
Pete79L82's Avatar
Pete79L82
They only seem to work good on drag race motors. On any endurance applications (oval track, road racing, street motors) where there is a lot of acceleration and decelleration they seem to show a lot of wear on the bearings.
They are made by TCI
Old Dec 8, 2004 | 09:30 AM
Brettmc's Avatar
Brettmc
If I remember correctly from installing my ATI a coupla months back, the fit is something like .0005".
Brett
Old Dec 8, 2004 | 10:14 AM
Glassbowtie77
Well, made in China or not, the piece is as well made as the factory piece I took off the car. The price was right, it was an easy install, it works perfectly, and that's all that matters to me. I am running a slightly modified L48 so I don't need anything special like you would for a race motor.
To Harmonic balancer question
