Camshaft Wiped A Lobe
Old Dec 9, 2004 | 12:28 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Camshaft Wiped A Lobe
I guess this is bad news and good news.
Bad News: Original 1980 Camshaft is toast
Good News: I guess I will be rebuilding my engine for sure next year.
I love shopping for parts
Les
Old Dec 9, 2004 | 12:43 PM
page62's Avatar
page62
Don't camshafts usually wipe lobes early on? I thought that a wiped lobe in a middle-aged engine was unusual. (I don't know, that's why I'm asking.)
And I assume your car is in winter storage...
Old Dec 9, 2004 | 12:50 PM
lars's Avatar
lars
Actually, the '80 thru '82 engines are noted for wiping out lobes around mid-life. Like the engine's mid-life crisis. My '82 wiped 2 lobes after 60,000 miles for no apparent reason. All the other lobes and lifters were like new.
Old Dec 9, 2004 | 12:56 PM
AGVI's Avatar
AGVI
My engine has 250,000 kms....it's more like the end of life, not mid-life.
Anyway, is it safe to drive my car to storage or should I tow it?
I'm assuming towing would be the way to go.
Les
Old Dec 9, 2004 | 01:09 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Were you missing any nuts or bolts after the intake and carb swap?
Old Dec 9, 2004 | 01:39 PM
adam's Avatar
adam
How did you learn this?
I would think that is the last thing to be thinking of when chasing a problem
with a mid or end life engine...
Old Dec 9, 2004 | 01:49 PM
AGVI's Avatar
AGVI
Can someone answer my question.
Old Dec 9, 2004 | 01:58 PM
mandm1200's Avatar
mandm1200
Les
I don't see any reason not to drive it. I assume the engine wasn't shut down the split second the lobe was worn off. The engine has been run awhile in this condition, a few more minutes should not hurt it more than what it is. Save the money towards the rebuild.
Old Dec 9, 2004 | 04:08 PM
lars's Avatar
lars
Drive it.
Old Dec 9, 2004 | 04:19 PM
TTop Tony's Avatar
TTop Tony
Whats the symptoms for a wiped lobe?
Old Dec 9, 2004 | 06:12 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Yes '80 -'82 L-48s were renowned for wiping a cam lobe between 50K & 90K miles. I have two '80s. The 53K Classic White'80 has signs of it going now ( missing already) and the other is the reason I got to buy it. The guy had pulled the engine in 1987 because of a cam lobe going away and he never got the engine rebuilt. I bought it without an engine and transmission.
The L48 camshafts steel was soft from the vendor. It wasn't just Corvettes but all GM L-48 engines during this time. jim
Old Dec 9, 2004 | 06:40 PM
AGVI's Avatar
AGVI
This Sucks!
Old Dec 9, 2004 | 08:04 PM
MotorHead's Avatar
MotorHead
Sorry I thought you were looking for an excuse to build a new engine,and you were actually pretty happy. I remember when I got mine rebuilt, it was runnigng great only using oil and fouling one plug, could not figure it out so I decided to get it rebuilt.
When i went to pick it up the engine builder told me the intake gasket was misaligned and that's why the one plug was fouling, couldn't have been happier with the new motor though
Old Dec 9, 2004 | 08:20 PM
AGVI's Avatar
AGVI
Wayne, did you do a stock rebuild with the original crank and rods?
I know you replaced the pistons....which did you use?
Dude, you are now my mentor...
Old Dec 9, 2004 | 08:59 PM
AGVI's Avatar
AGVI
I want to make my engine rebuild a sticky....self centered? no...need help? OH YES!!!
Old Dec 9, 2004 | 09:36 PM
MotorHead's Avatar
MotorHead
Kept the crank and rods, pistons were Speedpro flat tops with about 9.7:1 or so and they put in CC270H cam and put the stock heads back, had alot more power
Old Dec 9, 2004 | 10:35 PM
AGVI's Avatar
AGVI
Can I do the above combination with the Sportsman II heads you eventually put on? What were your numbers then?
Les
To Camshaft Wiped A Lobe
Old Dec 9, 2004 | 11:11 PM
MotorHead's Avatar
MotorHead
You should be in the 275-300RWHP range easy with Sportsman II's same as stock C5's
Old Dec 11, 2004 | 10:20 AM
AGVI's Avatar
AGVI
Stingray wants $8500 [including headers and pipes]to build me a 383 that will be just under 400HP. Why would I do that instead of just rebuilding my existing engine to the same level of HP for a lot less money...
Those guys are rolling in dough...
Old Dec 11, 2004 | 11:03 AM
gdh's Avatar
gdh
for @ $6500 you could drop in an LS1 + 6sp, no more carb etc. then just put your old block in storage.
