Differential Cover Again
Had to cut out spring bolts and one of the 2 back spring plate bolts broke, front didn't matter they were already broke. I have been spraying with blaster for a week but one broke, no prob i'm replacing cover anyway.
Car looks like it was zbarted a long time ago so frame seems good except for frame member by tank that wasn't sprayed and some loose rust inside rails.
Problem is is that 9/16" is too small for cover bolts, think i'll have to grind on the bolts some? I thought they were 9/16.
I was trying to get the cover off without taking out differential, I guess that is not going to be an option unless, anyone has an idea. At leaset the crossmember bolts loosened on the frame easy enough.
I guess it isn't midaswell but have too.
If that doesnt work, craftsman has a "bolt out" thing that will cut its self onto the bolt head. Pretty cool... but thats a last resort.
Have you hit the bolts with some serious penetrating oil? PB blaster?
Gary
Here is side view of the complete differential.
Gary
Note that the cover is bolted to the crossmember.
You can probably get away with leaving the strut rods in place
and unbolting the bracket fromn the cover.
The ends of the crossmember (cushions) come off of the frame
with LOTS of work. The best way I've seen is to use a gear puller
and a longer center bolt to pull it down and off. I stuck a pipe
inbetween mine and the frame to pry it off. The pipe took
a good beating on that job.
Once down and out, get the crossmember off (4 bolts).
If that's out of the way, you can use a grinder to take off
the heads of bolts that you can't get.
If you're not using 6 point sockets/wrenches, you are wasting
your time. As you noted, the heads have weathered significantly.
The metric idea works often .... maybe a good pair of vice-grips.
PS - It IS possible to get the top 4 bolts with the crossmember
in the car. I have done it. I do NOT recommend it.
Oh yeah - be prepared to discover that you may need new side yokes.
They wear on the inside end. If they slide in and out more than 1/8" -
it's definitely time.
Ooops - didn't mean to repeat what Gary already stated.
Good Luck
Thanks Guys
Gary
I've heard of lift bars... But that front mount gives a whole new spin on that idea!
Gary
Do these new heavy duty covers ever break and what is the leaf sping torque spec?
