ID My Fiberglass Spring Please
My rear spring has an ASO sticker on it, along with model# & serial#. I assume the Manufacturer is ASO, but what does it stand for???
Eddie
Eddie
Eddie,
It is probably AO Smith. Also sold as the TRW fiberglass monospring. I have one of those I bought in the early 90's. The spring tag has a part number with a small hole punched out to indicate the LB rating. If you look close on top of the spring, you can see the part number and I might be able to decode it.
-Mark.
-Mark.
Hey Mark!
The model # punched on the sticker is the last and largest #. 105
And the serial # is 0200792. I'm assuming it's a pretty hefty spring.
Do what you can to run those #'s. I realy appreciate it.
Eddie
Eddie
Does the sticker on the spring look like this?
