Exhaust Headers
Old Dec 15, 2004 | 08:02 PM
hotrodrik's Avatar
hotrodrik
Default Exhaust Headers
Which header out there fits the best, in a small block car. I have a 77 ,stock for now but at some point I'm adding the vortec heads ,[ that should wake things up a bit] manifold & carb .After I finish the rear suspension I'm upgrading the exhaust and was interested in hearing on how different brands of headers fit. Any help would be great.
Old Dec 15, 2004 | 09:00 PM
isosceles's Avatar
isosceles
Dynomax Ceramics fit well. Don't know if the standard 1 5/8" primaries are big enough for hi perf motors though. We'll soon see when I get my car back on the road.
The fit and finish is excellent.
Old Dec 15, 2004 | 09:33 PM
onlyc34me's Avatar
onlyc34me
1st Gear
Just make sure they will perform with your newer heads. The fit & finish should be good. I have heard good things from others.
Good Luck.
Old Dec 16, 2004 | 09:25 AM
Glassbowtie77's Avatar
Glassbowtie77
I have a set of Summit full length headers on mine and they fit perfectly. Don't know however if they'll be ideal for the Vortec heads or not, just give them a call and tell them what your application is and they will tell you what the correct set and tube diameter should be.
Old Dec 16, 2004 | 09:49 AM
Graemeinvette's Avatar
Graemeinvette
I have a set of Hedman Headers and they are a good fit but, I am about to order a set of Dynomax Ceramics, since they will fit round my new Steeroids.
G
LFZ's Avatar
LFZ
my father has Hooker SuperComps on his 74 with Vortec heads..fits excellent, don't leak, however they hang low at the collector. If your car is low, they might get bottomed out some..but they look cool.
Old Dec 16, 2004 | 10:00 AM
XShark's Avatar
XShark
I have a Dynomax set in my 77. Fit & finish was great.
I'd suggest upgrading to Percy's dead soft gaskets, and even Stage 8 bolts.
I did not use them, and I haven't had any problems, but I plan to upgrade in the future. (although I did go back and tighten the bolts a few months later.. a few were a little loose)
Old Dec 16, 2004 | 10:17 AM
billy78sa's Avatar
billy78sa
check out bobchads site from cac, walker dynomax ceramic coated headers from summit for 230 plus shipping.
Old Dec 16, 2004 | 10:42 AM
Clint's C3's Avatar
Clint's C3
I have a set of Tri-Y "exhaust scavenging" chrome headers on order from Stan's headers ~ 400 + $20 shipping. They are recommended for keeping your low end torque and improving top end.
http://www.stans-headers.com/tri_y.htm
Old Dec 16, 2004 | 10:51 AM
XShark's Avatar
XShark
Bobchad's header pics
Bobchad has some great info on his site.
Old Dec 16, 2004 | 11:17 AM
Bobchad's Avatar
Bobchad
Thanks guys. Easy install on the 77. The only snag is the spacer for the a/c and that simply involved getting a 3/8 inside diameter x 1/2 outside diameter x 1 1/2 length spacer made by Hillman from Lowes and cutting it to the thickness of the ram horn less the thickness of the header flange using a dremel.
Everything else is a bolt on with the exception of matching the exhaust pipes to the collectors. I paid the shop that did my dual system to cut, match and weld the pipes.
Old Dec 16, 2004 | 11:20 AM
Ganey's Avatar
Ganey
The Dynomax Corvette SB Cerama-Coat fit & flow great, much better than is commonly known. Have been rec. them & many have them now.
If you want more info., you might want to see what many refer to as my Exhaust topic.
http://www.corvettefaq.com/c3/ganeyexhaust.htm
Old Dec 16, 2004 | 01:25 PM
an81shark's Avatar
an81shark
dynomax here. very easy install
To Exhaust Headers
