Rough Running
Old Dec 21, 2004 | 12:03 PM
RRROBB's Avatar
RRROBB
Default Rough Running
Last week my 1977 L82 started running very rough
(it was missing). I replaced the rotor, coil and distributor cap. it still ran rough. Replaced plugs and wires. Problem fixed!! This morning it started missing again. Anybody got any ideas what to check??????
Old Dec 21, 2004 | 12:16 PM
Schmucker's Avatar
Schmucker
Did you check the timing? Is it only rough at idle, but if your crack the throttle a bit does it smooth out?
Old Dec 21, 2004 | 12:18 PM
RRROBB's Avatar
RRROBB
schmucker
I haven't checked the timing yet. It did run very well for 1 day and as i was driving in this morning it began to idle rough and sounds like it is missing when you get on it.
Robb
Old Dec 21, 2004 | 01:16 PM
lars's Avatar
lars
Timing won't cause a miss. If you have an IR electronic thermometer, shoot the temp of the exhaust ports to identify the cylinder that's missing (cool port) and troubleshoot ignition and valvetrain issues back from there.
Old Dec 21, 2004 | 02:55 PM
Crash80's Avatar
Crash80
Have you ever had the valve seals replaced?
Old Dec 21, 2004 | 03:17 PM
pws69's Avatar
pws69
Put some Drygas (or similar water absorbing stuff) in the tank and drive it for a bit.....
Old Dec 21, 2004 | 04:39 PM
diablo kid's Avatar
diablo kid
Check the plug wires at each end and make sure they are pushed on tight. I installed new plug wires a couple of weeks ago and had the same problem as you, started up and drove it and all was ok, next time it had a miss. I found one wire at the distributor was not pushed on properly. Works fine now.
Old Dec 21, 2004 | 06:54 PM
glenga's Avatar
glenga
Next time it misses pop the hood and check if any plug wires are arcing onto the engine block. I had this problem once when I used cheap plug wires.
Old Dec 21, 2004 | 07:50 PM
boatman's Avatar
boatman
Default 77 Running Rough
Get a Dr. ReBuild Vacuum Line Kit for the entire carb, intake, air cleaner
and smog pump vacuum lines. This may take care of your problem, and definitely take care of any backfire like symptoms when you are running the engine up and letting off the gas when in neutral.
To Rough Running
