How many teeth do I have?
Old Dec 30, 2004 | 09:43 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Originally Posted by Z-man
I took the starter from my 350 and bolted it directly onto my 400 block. You shouldn't have any problems unless the flywheel has different teeth...
Just use the same flywheel as your 350 and voila!
400 and 350 blocks (all small blocks for that matter) are basically the same. Flywheels are interchangeable too if you also use same starter. That is why GM made em. Parts is parts.
Old Dec 30, 2004 | 09:48 PM
74FLCONV's Avatar
74FLCONV
Originally Posted by bobs77vet
...should be obvious in any event when you go to install it..
Right, but...I don't want to order a starter, pay for shipping and wait a week just to find out it won't work.
This is how the bolt pattern on my starter looks. Which mini-starter do I use?
D. Ocean
Miami, FLA
Old Dec 30, 2004 | 10:32 PM
kens 80's Avatar
kens 80
Default Late model replacement block
All Small block flywheels with a two piece rear main seal have the same bolt pattern and inner hub dia.. Big block,bolt pattern and center hub is also the same but some big block flywheels won't clear the elipitical shape on the small block crank.(big block rear crank hub is round). The "crate motor" one piece rear main seal uses a completely different flywheel.
Old Dec 30, 2004 | 10:41 PM
74FLCONV's Avatar
74FLCONV
So where does that leave me?
SB with staggered bolt starter...
Will an in-line bolt pattern mini starter work?
D . Ocean
Miami, FLA
Old Dec 31, 2004 | 12:36 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
D . Ocean
Miami, FLA
can you use a flash light and see if you have the mounting holes for a mini starter on the bottom of your block....they are about 4 " apart and they would both be parallel to the flywheel...not offset like yours...one of the previous posts has apicture of the bolt holes one is for a 153 tooth and one is for 168 tooth...when i get back in town i will look at the 350 i just pulled out and see if it has bolt holes for the staggerd starter as well as the other starter.... not sure if this helps....maybe buy the starter locally so you can take it back...
Old Dec 31, 2004 | 02:12 PM
ltlevil's Avatar
ltlevil
A SBC 400 is externally balanced 350's are internally balanced. If you put a 400 flywheel on a 350 or vice versa you will destroy the bottom end of the motor if you can let it run long enough with the vibration it will cause. As far as fitting, in-line 6 cylinders (250,292 ect..) also use the same flywheel and starters as a 350.
Old Jan 1, 2005 | 03:06 PM
LFZ's Avatar
LFZ
D . Ocean
Miami, FLA
Look under your block to locate 3 holes...if you have 3 holes...2 holes which are about 4 inches apart and inline with each other..a standard mini starter should work. My block has 3 holes..but my original starter was staggerred holes.
Old Jan 2, 2005 | 07:28 PM
bobs77vet's Avatar
bobs77vet
i'm back in town and heres the picture...if your set up looks like this an inline set up would work...
[IMG][/IMG]
Old Jan 2, 2005 | 11:58 PM
74FLCONV's Avatar
74FLCONV
Thanks for the pic. I haven't had a chance to climb underneath this weekend, but...I did find a "staggered" mini-starter which should be delivered by Tues.
D. Ocean
Miami, FLA
