Clutch Question
Old Dec 27, 2004 | 10:16 PM
glen242's Avatar
glen242
Default Clutch Question
New 383 Build
I am accumulating parts for my new 383 to go into my 3300# (3450# with driver) 'vette. DD says 385 hp 435 # torque. Using a ST-10 4 speed and have a clutch question. Car wil be 99% street driven, has a 3.36 rear, and 27.2" tires. On very rare occasions I would probably launch @ about 2000 rpm.
I am looking at Centerforce clutches, both Centerforce 2 and dual friction. What would be a better choice, or is there some other brand I should look at?
BTW, what does a stock 350 flywheel weigh?
Thanks,
Old Dec 28, 2004 | 02:00 AM
stingr69's Avatar
stingr69
Either one is fine. The DF setup comes only as a complete set while the Centerforce 2 parts come individualy so you could service it later as needed. On a low torque engine you might be better off with the Centerforce 2 but with the 383 you can go either way.
If it were my car, I would buy the Centerforce 2 for that application.
I think the stock flywheel is like 30-35 LBS.
-Mark.
Old Dec 28, 2004 | 08:30 AM
Gordonm's Avatar
Gordonm
I am using the Centerforce 2 on my setup. It has taken all the abuse I can throw at it. Plenty of drag strip launches and plenty of abuse. I have around 420 HP on my setup and after 6K miles it is still holding up fine. The DF is a good setup also but a little more $$$.
Old Dec 28, 2004 | 10:10 AM
oregonsharkman's Avatar
oregonsharkman
I have Centerforce 2 on my 383/440hp and so far so good-----much superior to the original clutch
Old Dec 28, 2004 | 09:37 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Had vibration issues with my Centerforce DF. Switched to a McLeod setup and have been happy.
To Clutch Question
