Has anyone used the rebuild kits for this? The shaft doesn’t seem to be scratched but the seal around it is leaking. If anyone has used one of these did you have good results? Are there any tricks of the trade I should know about?
Thanks,
Doug
I would suggest trying to repair it. If the repair doesn't take, you are not out much. I think the repair kits are less then 10 bucks. Might not hurt to rebuild the control valve while you are at it.
