What Spark Plugs Do You Use?
Old Dec 30, 2004 | 02:44 PM
Motor City Vette's Avatar
Motor City Vette
Default What Spark Plugs Do You Use?
Okay, I know there's a ton of choices for spark plugs, so I'd like to get your feedback on what plugs you've used and like. Here's my setup:
- L46 (350/350)
- Pertronix Ignitor II
- Pertronix Flamethrower II coil
- 8mm wires
I use my car for a driver (not racing), although I do occasionally like to get on it from stoplight to stoplight.
Old Dec 30, 2004 | 02:47 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
not the cheapest, but just plain old fashioned ac delco or bosch from the local parts store.
Old Dec 30, 2004 | 02:55 PM
zwede's Avatar
zwede
My 2 cents:
AC Delco: I don't like the black oxide. Seems they rust quite a bit after a year or so.
Bosch: Hate the screw-on insulator tip. Always comes loose.
Champion: Good plug. Solid tip (not screw on) and they are (I believe) zink coated so they don't rust.
NGK: Same pros as Champion. For some reason my 454 loves the NGK FR45's so that's what I run. Note: FR45 won't work on stock heads. I have aftermarket heads.
Old Dec 30, 2004 | 03:00 PM
greyghost79's Avatar
greyghost79
anybody using iridium??? what makes a spark plug worht $12.00 a piece?
Old Dec 30, 2004 | 03:07 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Accel shorties...as good as any I've tried
Old Dec 30, 2004 | 03:18 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Same plug here. Ever since it was first fired.
Old Dec 30, 2004 | 03:22 PM
Wrecked82's Avatar
Wrecked82
I am. Can get them for about $7 each if you search long enougn. Solved my rough idle. Love them.
Old Dec 30, 2004 | 08:34 PM
stingr69's Avatar
stingr69
Autolite are my first choice. After that I would run AC or Champion. I have never seen any benefit from a fancy plug personaly. The Autolites last longer without fouling in my experience. Probably has a wider heat range I guess.
-Mark.
Old Dec 30, 2004 | 08:38 PM
Cali,68,L-79's Avatar
Cali,68,L-79
I'm not sure but if pet rocks can sell out then people will buy anything. Damn why can't I think of these things.
Old Dec 30, 2004 | 09:11 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Been using Bosch Platinum since about 1980.
Old Dec 30, 2004 | 09:23 PM
isosceles's Avatar
isosceles
A/C Delco Rapidfires in the L48
Autolite Plats in the 383.
Old Dec 30, 2004 | 09:52 PM
Retro78's Avatar
Retro78
accel shorts, great with headers.
To What Spark Plugs Do You Use?
