Radiator removal procedure
Old Jan 1, 2005 | 12:01 AM
Secret Squirrel's Avatar
Secret Squirrel
Default Radiator removal procedure
Can some of you guy's shed a bit of light on the best procedure to remove a radiator from a '69 BB manual car????
Car is factory original(most of it )
I could just jump straight in and pull it apart, but i'm sure there's an order in which things are best done.
Nothing worse than getting something half apart only to find out you have to redo stuf to remove other stuff
cheers
Old Jan 1, 2005 | 01:26 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
It's pretty straight forward.
Drain the radiator.
Scribe the hood hinge outlines to the hood.
With a buddy, unbolt and remove the hood.
Disconnect the hoses.
Unbolt the brackets.
Lift that sucker out.
Old Jan 1, 2005 | 06:05 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Usually the best way....sometimes the only way...is to pull the radiator/shroud/core support as a unit.
You can't get the BB fiberglass shroud out by itself, as it won't clear the A frames. Can't get the radiator out without removing the shroud, and can't get enough wiggle room unless you at least loosen..or remove the core support.
I've found it easier to pull them as a unit. Think of the radiator as the "meat in the sandwich" between the shroud and the core support.
Reassemble it the same way with all the seals, and drop it in as a unit. The reason you see so many shrouds cut in half is that people try to get them out...and can't. Chuck
Old Jan 1, 2005 | 07:46 AM
Secret Squirrel
Thank you AW and Chuck for the feedback
Old Jan 1, 2005 | 08:10 AM
Steve's74's Avatar
Steve's74
Bingo. Pull it and replace it as a unit. You will have to remove the cooling fan first (may be obvious) and possibly the water pump for clearance. I also found it helpful on my '74 to remove the driver's side upper control arm from the frame bolts to provide a little extra clearance. This can be done safely as long as you have a jack stand under the lower control arm. This procedure seems to vary somewhat depending on the year - imy '74 has factory air and I pulled the A/C condensor as part of the "sandwich". And boy, the lower condensor fitting was a beetch!
But this is the only proper way to reassemble everything with the proper seals installed.
Steve
Old Jan 1, 2005 | 10:43 AM
jdmick's Avatar
jdmick
I just did this the first time yesterday on my 75. Take your fan off and unbolt everything. Don't forget that little rod that goes from the bottom up to the front. Getting that bottom A/C hose off isn't easy by yourself. After getting my headers and pipes out as one unit and pulling and fighting to get the radiator etc. out I was done wrenching for the day.
Old Jan 1, 2005 | 11:52 AM
bigvette1's Avatar
bigvette1
Default Rad Remove
Another point is to take out the 2 bolts on each side inside the fender wall holding the radiator frame in place. This will allow about 1 - 1 1/2" of forward clearance to remove the shroud and/or the radiator as an assembly, and get it off the A-frame. Fact - it is a PITA job, wear gloves and have a helper.
Old Jan 1, 2005 | 02:20 PM
Corvettes White's Avatar
Corvettes White
Another way is to pull the bolts holding the upper arms. It just barely worked for me having a 27” core.”
Happy New Year.
George
Old Jan 1, 2005 | 02:37 PM
redc3's Avatar
redc3
Default huh?
how much difference is there between years? i have a 78' and i pulled old rad out by myself, no hood removal, certainly no a- arms, no loosening anything other than the rad. pulled the fan, and that sucka came out. installed BB rad in its place by myself. what gives?
Old Jan 1, 2005 | 02:49 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Not all C3s are configured alike here in this area. My two '68's with no A/C, 4spd WITH the metal barrel shroud, the radiators CAN BE lifted right out after moving the barrel shroud towards the engine. I had a 1980 4spd car where also I could slide the shroud towards the motor & pull the radiator. Just did my '75 & 1973-'76 first design cars with the way the shroud is right up against the forward A-arm bolts, it's much easier to pull the whole support/radiator/shroud as a "unit" as others have mentioned.
Old Jan 1, 2005 | 03:05 PM
greyghost79's Avatar
greyghost79
i agree.
Old Jan 1, 2005 | 03:17 PM
redc3's Avatar
redc3
thanks for the info, im SO glad i didnt have to dive in after that ac line!
Old Jan 1, 2005 | 04:38 PM
Secret Squirrel
Thankyou all for the help
To Radiator removal procedure
