Steering Play (unequal)
Just finished rebuilding my frontend on my 1980 (bushings, springs, shocks). New powersteering valve about two months ago.
Had it aligned and rides much better. However, there is an evident difference in the play between moving the steering wheel left vs right????
Moving left has immediate effect. Moving right has approx 1.5" of play.
How can this be?
Thanks in advance for the advise.
So to go striahgt you are applying slight left steering and you have no play. Going right you feel the play.
I'd start by checking the steering box and rag joint.
It's easy to do. Just put the front end up on stands, (make sure you have the parking brake on and the rear wheels blocked.)
Remove the tire.
Center the steering.
Remove the small cap on the end of the steering ram. You will see a little nut inside of the ram.
Start the car, making sure that you don't put your arm through the steering wheel when you turn the key.
Notice if the wheels turn at all when the motor is running. They should not move at all. If they do, it's a sure sign that the system is not balanced.
Turn the nut slowly in one direction or another. Stop as soon as the wheels start to turn.
Slowly turn the nut in the other direction. Pay attention to how much you turn it until the wheels begin to move in the other direction.
Turn the nut back half the distance you just turned it.
Voila!! perfectly balanced steering.
I've been told that the factory biased the steering slightly to the left to offset the radius most roads have to facilitate drainage.
Also, the Chevrolet shop manual says to disconnect the assist cylinder (ram) from the frame when you conduct the valve balance procedure. There are probably two reasons for this.
1). I think that from a safety standpoint, it is probable best that only the assist cylinder rod is extending out and in rather than both front wheels moving lock to lock;
2). It is probably best that you only have the slight friction of the assist cylinder rod rather than the added friction of the ball joints, steering gear, steering column, and linkage pivots interacting while you do the valve balance procedure.
Jim Shea
Jim Shea
Minimizing friction makes good sense too. Next time I have to do it, I"ll disconnect. It only takes a minute longer.
As for the bias, a dealer told me that a long time ago, and for some reason I remember it. I thought it was kind of a dumb thing to do, although there was a certain logic in it!
If the valve was very bad, a complaint was issued to the manufacturer, Saginaw Steering Gear. The assembly plant would send the car to a repair bay where the valve was pulled and returned to Saginaw and another valve installed in its place. (They hated to send cars to the repair area.)
