Do I need valve cover hold-downs?
Old Jan 4, 2005 | 09:36 PM
74FLCONV's Avatar
74FLCONV
Default Do I need valve cover hold-downs?
Just picked up a pair of old-school (read: Thick & Heavy) finned cast aluminum valve covers. Do I need valve cover hold-downs or are those specifically for the stamped steel covers?
D. Ocean
Miami, FLA
Old Jan 4, 2005 | 10:55 PM
ZD75blue's Avatar
ZD75blue
I've always thought they are a stamped sheetmetal item only. Not to say they might not be beneficial on a cast valve cover...
I'd give it a shot with one of felpro's re-useable valvecover gaskets and a tack coat of gasketmaker. If both surfaces are relatively true... you shouldnt have any issues!
Might want to lay a straight edge across the valvecover gasket surfaces just for grins and giggles...
My .02, Try it with out, add em if it needs them!
Old Jan 4, 2005 | 11:00 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
A heavy cast valve cover would probably crack before it would bend enough to effect sealing
Old Jan 4, 2005 | 11:45 PM
standup's Avatar
standup
I don't think it's possible to use the hold downs on the LT1 style finned covers because they have a raised area around the bolt hole.....
As suggested above, gasket cement on both surfaces should do the trick........
Old Jan 5, 2005 | 09:57 AM
joe73vette's Avatar
joe73vette
you don't need hold-downs with aluminum valve covers, just a flat washer under the bolt. also, don't glue both sides of the gasket, you'll never get them off. glue the gasket to the valve cover and lightly rtv the motor side. joe
To Do I need valve cover hold-downs?
