Prepping Block for 383
Old Jan 5, 2005 | 10:12 AM
mandm1200's Avatar
mandm1200
Default Prepping Block for 383
I have a couple questions in regards to getting the block ready for the 3.75" crank. I purchased a block that was prepped for a 3.48" crank. I set the crank in the block and installed pistons/rods to check and see where I it would need grinding. There are 2 locations where the rod nuts hit. I just purchased a dremel to grind the affected areas.
What is the spec on the clearance needed? There were a few other nuts that were fairly close to hitting, I would estimate .030.
After the block is ground, can I just take it to the car wash and clean it, dry it, and spray it with something like WD40?
Old Jan 5, 2005 | 10:20 AM
Gordonm's Avatar
Gordonm
I would say you want a minimum of .050 clearance at all points due to the motor growing as it heats up and moving a little in the upper rpm limits. Yes after grinding wash it very good and clean out all passages. Quickly coat it with a WD 40 or something like that. I then take a clean white paper towel and clean the cylinders with auto trans fluid. This type of fluid is designed to suspend dirt in the fluid. You will be surprised at how much stuff is still the in cylinder walls. Keep doing this until you see the paper towel just stay red form the trans fluid. This will help seat the rings quickly. Try to keep everything as clean as possible.
Old Jan 5, 2005 | 10:21 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
have you read any of the magazines articles on build a 383? if not i can see i can dig one up for you they talk about all that stuff....
edit :heres what i found so far....
chevy high performance 5/04 and 6/04
popular hot rodding 10/04 and 11/04
Old Jan 5, 2005 | 10:36 AM
GTR1999's Avatar
GTR1999
Gordon good info on the tranny fluid! Learn something new every day!
Ok now do you know a good place to find a cylinder brush? Local places didn't have one, Eastwoods didn't have one?
Gary
Old Jan 5, 2005 | 11:00 AM
Gordonm's Avatar
Gordonm
Gary
This was a trick my machinist gave to me. It took about 3 to 4 paper towels per cylinder to get them clean. This was after washing the block. It is amazing the dirt and grit that is left in the cylinder wall grooves that did not come out with washing. It is noticably cleaner after this is done. You can really see the cross hatch in the cylinders.
Old Jan 5, 2005 | 11:05 AM
joe73vette's Avatar
joe73vette
It's amazing how much grit stays in the walls - I use windex and about the same number of paper towels. Joe
Old Jan 5, 2005 | 11:18 AM
Fevre's Avatar
Fevre
You will also need to grint some of the rod bolt heads to clear the cam unless you are using a rod with cap screws. You can put 2 peices of masking tape (not scotch) on the cam lobe to get the clearence you need. I think there is only 2 bolts heads that need grinding but you will need to balance the assembly so grind one from the other 2 journals to get them back in balance. I used a scale to make sure I got them with a couple grams. I think that as long as you balance the rod weights for each journal you should be fine, some may say you need to get all 8 rods the same weight but unless you are reving 6000+ rpm's I wouldn't think that is necessary. If you are reving 6000+ get some rods with cap screws.
Old Jan 5, 2005 | 11:28 AM
joe73vette's Avatar
joe73vette
Do you still have to do that if you use 400 sb bolts? They come with the corners already ground off. I got some from ARP when I built my 400 and didn't even think about it. Thankfully it worked fine, even with a GM cam. Joe
Old Jan 5, 2005 | 11:37 AM
Fevre's Avatar
Fevre
Not sure on that one, did you use the 400 rods? I think they are little diff shape. Also would depend on the cam lift.
Old Jan 5, 2005 | 11:56 AM
joe73vette's Avatar
joe73vette
Yes, 400 rods and an L82 cam which isn't very high lift. I'm glad I decided to stick with 350 ci on my vette. Too many unknowns. Joe
Old Jan 5, 2005 | 11:57 AM
mandm1200's Avatar
mandm1200
Fevre
When I purchased the rotating assembly from the machine shop he knew which rod head bolts to clip so that part is done.
Prior to getting the parts, 9 months ago, I read on a web site what the rod to block clearance should be. However, I cannot find that site and it was not a spec that was from a bonaifide engine builder. I could go with 50 thousandths but I only wanted to take the minimum at the minimum amout of places. Don't get me wrong, I'll do what is nesessary.
To Prepping Block for 383
