High-Torque Mini Starter Suggestions?
Old Jan 20, 2005 | 10:28 PM
singedfur's Avatar
singedfur
Default High-Torque Mini Starter Suggestions?
I need a high-torque mini starter for my Corvette. What are you guys using? Summit has a million to pick from: what do I look for? Anything to stay away from?
Old Jan 20, 2005 | 10:31 PM
oregonsharkman's Avatar
oregonsharkman
Powermaster Xs---------good for up to 18:1 CR--mines only 10.3:1 but it weight ALOT less.... I think it's like +/- 200lb/ft torque
http://store.summitracing.com/defaul...tarter&x=0&y=0
Old Jan 20, 2005 | 10:53 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I bought a mini like this one from ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...948631555&rd=1
Old Jan 21, 2005 | 06:18 AM
Gordonm's Avatar
Gordonm
I have the same one. Paid 100 for it. Never had a starting problem since.
Old Jan 21, 2005 | 07:54 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I bought the Summit brand mini starter for up to 12:1 compression.. I paid around $150 for it. Haven't used it yet..
Old Jan 21, 2005 | 08:18 AM
mrvette's Avatar
mrvette
Someone said parts houses has these, and they fit later SBC blocks, and prices should be lots cheaper as 'rebuilts'....any clue as to what they fit???
GENE
Old Jan 21, 2005 | 08:19 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
What is the reason for buying a mni starter, my rebuilt stock starter works fine ?
Old Jan 21, 2005 | 08:27 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
If a guy needs a starter....might as well get one that weighs less.
Old Jan 21, 2005 | 08:33 AM
Twin_Turbo's Avatar
Twin_Turbo
Tilton XLT, very small.
Old Jan 21, 2005 | 08:41 AM
GrandSportC3
Reasons for a mini starter:
1) less weight
2) less stress on the bolts that hold the starter motor. I broke off a piece of my engine block (where the starter mounts) because of too much stress on those bolts...
Old Jan 21, 2005 | 08:43 AM
Twin_Turbo's Avatar
Twin_Turbo
Let me guess, you were not using the additional strap?
Old Jan 21, 2005 | 08:46 AM
MotorHead's Avatar
MotorHead
From what I can understand the top reason is less weight, like what 5 lbs ? I will try and lose that myself and save some money
Old Jan 21, 2005 | 08:51 AM
ZD75blue's Avatar
ZD75blue
Strap?
Old Jan 21, 2005 | 08:52 AM
GrandSportC3
Didn't use the brace on the starter..but I never did on any of my Vettes...
Old Jan 21, 2005 | 08:54 AM
Twin_Turbo's Avatar
Twin_Turbo
The higher the compression the more prone to cracking it is when not using that brace, it's not there for nothing. It also helps prevent warpage of the block due to the weight of the stock starter hanging there. Another good idea for high compression motors is to use a start retard.
Old Jan 21, 2005 | 09:00 AM
Edzred72's Avatar
Edzred72
Although there are other cheaper fixes for starter heat soak...some guys install mini's to solve this age old chevy starter problem associated with headers.
Eddie
Old Jan 21, 2005 | 09:06 AM
MotorHead's Avatar
MotorHead
OK that's a good reason, another would be header clearance porblems on certain headers, don't get me wrong here, I was looking at them a while back and you know I like to spend money on the Vette even for stuff that doesn't actually do anything but I couldn't bring myself to buy one to replace my perfectly functioning rebuilt stock unit. Now on a scratch engine buildup if you didn't have a good starter, it certainly makes sense
To High-Torque Mini Starter Suggestions?
Old Jan 21, 2005 | 09:09 AM
GrandSportC3
Never had any header clearance issues with my stock starter...
Old Jan 21, 2005 | 11:33 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I have a summit brand on my 10.5:1 434. It works great. Lots of power to start it. Nice and small to work with.
Why would anyone purposely buy a full size starter that uses more current, weighs more and is less reliable?
Old Jan 21, 2005 | 11:35 AM
Fevre's Avatar
Fevre
Got the same one and love it.
