High-Torque Mini Starter Suggestions?
Old Jan 21, 2005 | 11:47 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by Fevre
Got the same one and love it.
I think that the Summit starters are actually Powermaster starters with the Summit logo on it...
Old Jan 21, 2005 | 11:53 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
does anybodies hi torque starter make a whining sound as it disengages and slows down? almost like the wind down of a siren?
Old Jan 21, 2005 | 11:55 AM
GrandSportC3
I wouldn't be able to hear it on my car... I'm sure that the car is louder than the starter...
Old Jan 21, 2005 | 12:15 PM
singedfur's Avatar
singedfur
So why are some of them $150 and some $250? Is it a matter of brand name or something? I'm glad to hear the Summit starter is working well for you guys.
I'm looking to fix heat-soak issues. My Hooker headers were frying out the stock starter.
Old Jan 21, 2005 | 01:32 PM
markdtn's Avatar
markdtn
I am using a stock C4 L98 mini-starter. Available from GM and rebuilt from most parts stores.
Old Jan 21, 2005 | 01:38 PM
Solid LT1's Avatar
Solid LT1
Same here, "Keep your GM car all GM" is what the air cleaner sticker says, I like my Delco (OK Nippon Denso, Japan) L98 starter.
Old Jan 21, 2005 | 02:13 PM
Paul L's Avatar
Paul L
A little more expensive than others but it has performed well.
Old Jan 21, 2005 | 02:19 PM
baja216's Avatar
baja216
I'll be doing the same thing this spring!
Old Jan 21, 2005 | 04:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've got one of the GM mini-starters that looks like a small stock starter. The '77 now starts quickly, and never has heat-soak or battery issues (I think the fried stock starter ate my battery).
Old Jan 21, 2005 | 08:16 PM
singedfur's Avatar
singedfur
I did not realize the C4s used a mini-starter. Does it have high gear reduction like most others? Any particular year I need to ask for, or will any C4 starter work? Thanks!
Old Jan 21, 2005 | 09:22 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I also have had great sucess with a Summit starter. I got it for both weight reduction and to eliminate heat soak problems.
Old Jan 22, 2005 | 03:58 PM
markdtn's Avatar
markdtn
Mine is from a 91, Hollander says 88-91 (except ZR1) are the same. No other interchange. It is a gear reduction type.
Old Jan 22, 2005 | 04:01 PM
  #33
Twin_Turbo's Avatar
Twin_Turbo
this is my mini mini starter
Old Jan 22, 2005 | 05:19 PM
  #34
mandm1200's Avatar
mandm1200
I may try this one out. AC Delco for $99.
http://www.4alterstart.com/pages/sto...m/racestarters
Old Jan 22, 2005 | 07:22 PM
  #35
bobs77vet's Avatar
bobs77vet
your right now that it has a couple of days of turns on it and the car is running its not noticeable....
Old Jan 22, 2005 | 07:37 PM
  #36
C3 Stroker's Avatar
C3 Stroker
Originally Posted by oregonsharkman
Powermaster Xs---------good for up to 18:1 CR--mines only 10.3:1 but it weight ALOT less.... I think it's like +/- 200lb/ft torque
http://store.summitracing.com/defaul...tarter&x=0&y=0
...got one in my '69, works great & saves weight.
Old Jan 22, 2005 | 07:43 PM
  #37
LFZ's Avatar
LFZ
The summit starters are actually made in Canada, and they go by the same specs and looks as the Powermasters. I have one on my car getting ready to install, and my neighbor got one for his last year when he had starter heat soak problems. They are quality build and at a great price!
To High-Torque Mini Starter Suggestions?
Old Jan 22, 2005 | 10:20 PM
  #38
73jst4fun's Avatar
73jst4fun
Originally Posted by Jughead
I bought a mini like this one from ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...948631555&rd=1
Ditto, bought the same one also and it's worked great and half the weight of the OEM one..
Old Jan 22, 2005 | 11:10 PM
  #39
Joe Buck's Avatar
Joe Buck
Bought mine from Ecklers about 6 months ago, driven my car about 2,000 miles, and just yesterday it fell apart! Had to manually hold it in place to start my car...now I have to use Lockthread to keep it in place...
Old Jan 23, 2005 | 08:19 AM
  #40
Larry3x2's Avatar
Larry3x2
You guys are discussing two issues... Mini and high torque. I have a Powermaster Xs torque for header clearance and starting torque for my 434 w/ 11:1 compression. It's a mini but also has a gear reduction system to optimize torque. The ebay deal was not a gear reduction starter although it could be called mini.
Larry
