Thick(er) carb gasket?
Old Jan 23, 2005 | 07:04 PM
74FLCONV's Avatar
74FLCONV
Default Thick(er) carb gasket?
Does anyone have info on a thicker, heat-insulating carb gasket (not a phenolic $99 carb spacer) for the Q-Jet? Someone at the local speed shop mentioned a 1/4" thick gasket that also insulated from heat.
D. Ocean
Miami, FLA
Old Jan 23, 2005 | 07:41 PM
Cali,68,L-79's Avatar
Cali,68,L-79
I have a phenelic spacer under my BG 750 and it did make a difference in solving idle speed fluctuations.
Old Jan 23, 2005 | 07:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i'm running a 1/2 phenolic spacer and it cost about $29 under my speed demon
Old Jan 23, 2005 | 10:26 PM
74FLCONV's Avatar
74FLCONV
Does the spacer replace the gasket(s) or must you make a "sandwich" of the spacer between two gaskets?
D. Ocean
Miami, FLA
Old Jan 23, 2005 | 10:27 PM
bobs77vet's Avatar
bobs77vet
D. Ocean
Miami, FLA
gasket has to go on either side
Old Jan 23, 2005 | 10:30 PM
73jst4fun's Avatar
73jst4fun
D. Ocean
Miami, FLA
D, Holley makes one that is in the Summit /Jegs catalog that you just use without gaskets, I replaced mine and went with a 1/2" spacer. With spacers you need the gaskets...15" of snow in TR, see what you missed.................
Old Jan 23, 2005 | 10:42 PM
Mr Fanuc's Avatar
Mr Fanuc
I am running a 1/4" thick gasket under my q-jet. The rebuild kit came with a standard paper gasket and the thick one. You should be able to pick this up at your parts house. The gasket has torque limiters the bolts go through to keep from crushing it.
Old Jan 23, 2005 | 10:57 PM
lars's Avatar
lars
The stock Q-Jet gasket is a 1/4" thick insulating gasket. If you're currently not running this gasket, simply get a correct 1/4" gasket from any NAPA store. If this gasket does not provide adequate thermal insulation, you can then consider using a heat shield or a phenolic part. But use the stock thermal gasket first.
Old Jan 24, 2005 | 08:20 AM
vettfixr's Avatar
vettfixr
Old Jan 24, 2005 | 08:56 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
The last one I bought for my '75 a few years ago(same as '74), I remember GM even calls it an "insulator"
Old Jan 24, 2005 | 09:00 AM
74FLCONV's Avatar
74FLCONV
That must be what I'm looking for.
Thanks all,
D. Ocean
Miami, FLA
To Thick(er) carb gasket?
