Body alignment question??????
Old Jan 24, 2005 | 12:06 PM
GRAYGHOST's Avatar
GRAYGHOST
Default Body alignment question??????
The hood on my 78 does not line up with the left fender. I have
seen these hard rubber bumpers in catalogs that they claim are
used "by the factoery" to align the hood with the fenders. I even
saw a couple of cars at this past weekends NCRS Meet with these
bumpers on the fender flanges. My questions is, if I put these things on my car will I crack the paint on the hood or worse damage the fiberglass?
Thanks,
Pat
Old Jan 24, 2005 | 12:15 PM
vettfixr's Avatar
vettfixr
If you have a slight misalignment they should be OK. But if you're talking 1/4 inch or greater I would start by shimming the hinges on the hood and making sure the latches are adjusted correctly.
Old Jan 24, 2005 | 12:57 PM
GRAYGHOST's Avatar
GRAYGHOST
I've got more than .25 inches. I've tried adjusting the hood
but that seems to create more problems than it fixes. The hood fits great except in this one spot. I may just have to live with it! The bumpers would be the ideal fix but I'm really afraid that they too will create more problems.
Old Jan 24, 2005 | 01:01 PM
NHvette's Avatar
NHvette
Well, they are cheap enough ... try using a bumper to bring it up
about 1/8". This will make the difference much less noticable.
You're supposed to trim them to the height needed.
IMO - I don't think 1/4" is too much, but use your best judgement.
Old Jan 24, 2005 | 01:39 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Mine is the same on the right fender. Mine started to crack the pain where it is low.
Is the area in question near where the hood support mounts?
Look for cracks on the inside of the hood. Mine cracked on the passenger side directly opposite the hood support.
I think the rubber spacers are the way to go Try it out with some small pieces of faom taped there first. If the height looks right then order the rubber and cut to the same size.
Good Luck
Old Jan 24, 2005 | 01:50 PM
GRAYGHOST's Avatar
GRAYGHOST
If I use the bumpers, I will be "flexing" or "bending" the hood at
the point where I install the bumpers. Won't this crack the paint?
Old Jan 24, 2005 | 04:38 PM
redc3's Avatar
redc3
of course it will crack the paint if you go to far. i have about a 1/2 piece about half way between hinge and lock. all your looking for is a little nudge, not a great adjustment. truth is these fiberglass bodies were poorly/quicly made. and just need some tlc
Old Jan 24, 2005 | 10:11 PM
68/70Vette's Avatar
68/70Vette
Has your car ever been in a front collision? When I bought my 1968 Corvette in 1973, the hood also did not fit the body. The seller did tell me that it had been in an accident and the car had not been properly repaired. Anyhow I bought the car. (very low price and like new interior). I assumed that repairing it wouldn't cost very much.
The small mismatch in hood to body, turned out in fact, to be much more expensive to repair than I guessed. There were a lot of unseen things in the body work that can often need to repaired when you have a noticeable hood/body fit poblem. I paid to have the body work redone. Anyhow as of this date, the repair work is 30 years old and has not cracked and everything is a perfect fit. The man who did my repair was truly a professional craftsman.
Perfect fit?? Actually maybe too perfect of a fit. My front bumper, which actually looks really good, does have some slight signs of age. I have a new replated front bumper that I bought from someone at NCRS.org. It doesn't seem to be a repro bumper. I thought I'd just bolt it on. Didn't work. The guy that did my front end repair, custom fit the front of the car to the existing front bumper! The match of the body work of my car to the bumper is exact, but only my existing bumper will fit!!!
To Body alignment question??????
