From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Originally Posted by XFIRED
Darth, I would just replace the car
Now I don't think that's necessary... but I personally don't think you need an air filter. I removed mine when I cut my lid and it seems to flow tons better
I check mine at each oil change. If it needs attention, I act accordingly. It isn't that hard to access, you just have to be dressed so that you don't mind leaning on something dirty. - That's why I do it when I am changing my oil - I'm already in my 'working' clothes.
I have a K&N, but if I had a paper element filter, I would change it depending on my driving conditions. If you live in a really dusty, dry climate, then you probably ought to change it more often.
Just for reference, the Helms specifies every 30,000 miles.
I just finished cleaning and reoiling my K&N; I do that 2-3 times a year.
Check your owner's manual for recommendations on the stock paper filter.
Wow! 2-3 times per year to clean and oil the K&N???? - That seems excessive to me. If a paper filter, in the manual, is supposed to last 30k miles, which even on daily driver would be 2+ years..... 3 times a year maintenance seems like overkill on a K&N? Am I wrong?
From: SCMR Rat Pack'r Charter Member..Great Bend KS
No, you are right.
The K & N filters better as it gets dirty. I have a K & N on my daily driver VW and it hasn't been cleaned in four years.....that car still gets 36-38 mpg on the highway.
The AC-Delco paper filter in the Vette gets replaced every 20K miles.
