Delrin = 2 hrs
Old Feb 24, 2006 | 03:26 PM
  #81
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Originally Posted by Scoob
onedef92...there are your hollow aftermarket pieces. Seems we were both correct.
Ecklers = hollow
MidAmerica = solid
I learned something today.
I thought I'd seen 'em supplied both ways aftermarket. I just couldn't remember who supplied what. I still don't know why some users are experiencing premature failure from the hollow spacers, though. I don't see how torsional stresses could be so adversely applied to a rotating object, but then again, I'm no mechanical engineer.
Old Feb 24, 2006 | 03:29 PM
  #82
onedef92's Avatar
onedef92
Originally Posted by behnevette
I've said it many times before. Unless you really enjoy rebuilding your headlight motors, don't waste your time to save a couple of bucks. The Home Depot ones just won't last. I got less than a week out of mine.
Eckler's on the left, Home Depot on the right:
Big difference in size, too. That explains why the HD ones crushed.
The fit should be tight, and the cheap bushings were very sloppy.
I really like Home Depot, but they're not an auto parts store!
And to add another wrinkle, the Home Depot bushings I got did not fit cheap and were tight! And they're still holding up! And they're hollow, too.
I think it's a quality control issue with the HD bushings, but I'm still not convinced to write them all off as failure-prone.
Old Feb 25, 2006 | 12:24 AM
  #83
Insane1's Avatar
Insane1
Ecklers = hollow
MidAmerica = solid
AutoZone = solid
Old Feb 25, 2006 | 06:09 AM
  #84
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Originally Posted by onedef92
Call first. Home Depot usually stocks them. But I wouldn't wanna' drive that far and get fronted.
The HD bushings measure 27/64" x 29/64" The UPC code on the package is 30699 87278. Hope this helps.
Thank you sir, I was about to ask for the measurements.
Old Feb 25, 2006 | 08:15 AM
  #85
Casethecorvetteman's Avatar
Casethecorvetteman
If these HD bushings youre showing here are as hard as it seems youre saying they are, then youre no better off with them over steel shims in the long term, Time will be all that will tell what we see with the different methods we have all used here.
Old Feb 27, 2006 | 04:17 AM
  #86
Qiken's Avatar
Qiken
Originally Posted by jarrettjp
hi *89x2*! no, i never took the motor assembly off the car.from what i've read here on the forum the bushings can be changed out without the motor removal.the drivers side is the left side isn't it? the postings refer to the left side and i can remove the three screws and pull the gear out.but it looks like the whole assembly will have to be removed.thanks---john
I have been putting off the replacement of mine as well got them from midamerica,Looks like the best advice is to remove the whole assembly??
Old Feb 27, 2006 | 05:44 AM
  #87
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
That is correct
Old Feb 27, 2006 | 06:49 AM
  #88
Casethecorvetteman
Originally Posted by *89x2*
That is correct
The time it takes to remove them and get them on your bench, you will save in the ease of working on the assembly while its off the car. Pretty simple to put back on too, would you agree with that 89x2?
Old Feb 27, 2006 | 12:28 PM
  #89
onedef92's Avatar
onedef92
No problem. Holler back if you need further tech support. I'm thinking about running a poll to see what the failure rate is for HD, Lowe's, AutzoZone, and other aftermarket bushings....
Old Feb 27, 2006 | 12:30 PM
  #90
onedef92's Avatar
onedef92
That is correct
My vote is to remove the entire unit, too. But I can see someone being able to shortcut the procedure once they've mastered the technique.
Personally, I've done the job four times on my Vette and other enthusiast's cars.
It does get easier with experience, then again, no one ever got worse at ANYTHING by practicing....
Old Feb 27, 2006 | 04:03 PM
  #91
dnut24's Avatar
dnut24
well i go that piece in today, slapped it back together during lunch. only problem is now the headlight sits lower then the hood, rather then flush. i didnt have time to look into it, but my guess would be that since i had to remove the whole assembly including lower and upper cover to get the piece in a vice, theres some play in the falt portion of the closed headlight. and i basically just tightend it without any adjustments. i cant think of anything else it be.
Old Feb 27, 2006 | 04:10 PM
  #92
*89x2*'s Avatar
*89x2*
I would agree that the time it took to remove the 4 nuts and 2 screws was time well spent - maybe 3 minutes total...
The flip side was, my back didn't hurt from bending over for the entire 30-40 minute job
Old Feb 27, 2006 | 09:26 PM
  #93
Insane1's Avatar
Insane1
I didn't remove any covers when I did mine. I just used a small punch and a hammer to tap out the roll pin. I actually used the top of the washer and ryer for my workbench.
Old Feb 27, 2006 | 10:41 PM
  #94
dnut24's Avatar
dnut24
guess you havent read the trouble i went through. the pin would not come out at all on the driver side. broke cpl punches and cpl drill bits trying to drill it out. ended up having to cut the bracket off. big pain, glad its over. glad everyone elses pins came out freely.
Old Feb 28, 2006 | 01:01 PM
  #95
onedef92's Avatar
onedef92
Sounds like your headlight door is misaligned. There's a screw on the underside of the door you can adjust to make it flush again.
Old Feb 28, 2006 | 01:15 PM
  #96
dnut24's Avatar
dnut24
yea that was it. when i had the light mounted i took the top cover off and then untightened the bolts a bit and pushed it flush, then retightend. this happened since i had to take it apart with the trouble i had and put it together without it on the car.
i'll tell you i'm glad the ordeal is over. if these HD bushings fail on me i'm tossing this headlight system and getting the flush c6 style lights.
Old Feb 28, 2006 | 03:40 PM
  #97
onedef92's Avatar
onedef92
I think you'll be good. When I overhauled my headlamps, I broke both of the motor armatures and had to replace them.
I searched nearly two weeks before locating a local shop that sold Bosch eqivalents. I don't know who supplied the OEM units to GM. It was a labor of love, but I now have the satisfaction of knowing the job's done right and I can pass on what I've learned to other enthusiasts like yourself.
To Delrin = 2 hrs
Old Mar 1, 2006 | 08:16 PM
  #98
88Z51's Avatar
88Z51
Originally Posted by Dale1990
.....I can see why they failed. I think those are the wrong ones. The ones I used on my 90 Vert had nowhere near that much empty space in the middle. The size was 1/2 x .194 x 1/2 - only .194 center so there is plenty of meat......
Getting back a little late on this one, but it would seem this could easily be the answer as to why so many of us have had failures with the hardware store stuff. The HD ones measure .324" ID whereas the ones Dale1990 used (and had success with) have MUCH thicker walls with a .194" ID. As well as being almost .080" larger on the OD allowing for a tighter fit.
Here is a pic of the Home Depot ones that lasted four cycles on my 1988:
Old Mar 2, 2006 | 12:55 PM
  #99
onedef92's Avatar
onedef92
Still, how do you explain the fact my HomeDepot bushings have lasted nearly four SEASONS?
Old Mar 2, 2006 | 01:02 PM
  #100
Casethecorvetteman
You got lucky!!
