Delrin = 2 hrs
Old Mar 2, 2006 | 02:14 PM
  #101
Scoob's Avatar
Scoob
Originally Posted by onedef92
Still, how do you explain the fact my HomeDepot bushings have lasted nearly four SEASONS?
Do you drive at night?
Old Mar 2, 2006 | 03:01 PM
  #102
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I am guessing the HD/Lowes bushings are not exactly made to a high precision so I would think it is possible the various tolerences/wear on your gears and the bushings happen to match up better then someone else's setup. A few thousandths can make a big diference on the failure rates. You might have also got a better batch of nylon.
Or...you are just luckier than the others
Old Mar 2, 2006 | 03:20 PM
  #103
dnut24's Avatar
dnut24
i hop ei'll be one of the lucky ones as well.
Old Mar 2, 2006 | 03:21 PM
  #104
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I 'spect. But I'm not the only Forum member who's successfully installed HD bushings. But I agree that it is possible the various tolerences/wear on my gears and the HD bushings happen to match up better than the next man's setup.
My Vette is a seasonal toy, but it does get driven at night and in rain, snow, early morning and other situations requiring headlamp use. No problems at all.
I don't believe in luck. But I am blessed.
Old Mar 2, 2006 | 04:16 PM
  #105
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
...you rarely use your headlights
Old Mar 3, 2006 | 09:44 AM
  #106
onedef92's Avatar
onedef92
If they were gonna' go ****-up, they would have done so by now. Most people say their lamps only lasted for a few cycles with HD bushings. I'm good and satisified with the performance and durability of mine.
