4 Wheel Alignment: How Often?
Old May 2, 2006 | 02:50 PM
Red Tornado's Avatar
Red Tornado
Default 4 Wheel Alignment: How Often?
How often should this be done, as a matter of good maintenance practices? Once a year? Less often?
Old May 2, 2006 | 03:03 PM
pcolt94's Avatar
pcolt94
This is a real judmental item but I think a year might make you more comfortable. I don't do that but if I sence a problem I go right in to get it checked regardless of time factor, cheeper than tires and not that expensive. I guess depends on your driving. Charge on
Old May 2, 2006 | 03:27 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I wouldn't look at this as a "time" event. I think I'd do it about every 20K miles or so... unless some event occurs before that which may lead you to believe that an alignment is necessary.
(you know, like taking the Dana out for a gear change...)
Larry
code5coupe
Old May 2, 2006 | 06:11 PM
Jet-Jock's Avatar
Jet-Jock
As long as nothing is worn, it drives true and straight and no uneven wear no reason to make any changes. I'm on my second set of GS-D3's so probably about 35K now on the same alignment. It still is true and perfect wear even after switching the fronts from 8.5" to 9.5" wheels.
Of course that will change shortly as I'm going to replace the outer tie rods which will force another alignment. I use Chevy to do the alignment. They seem to get it right the first time unlike Firestone.
Old May 2, 2006 | 06:15 PM
Pete K's Avatar
Pete K
Brad,
Last alignment I had was in 1992. I am probably due again.
Old May 3, 2006 | 10:44 AM
Red Tornado
To all: thanks for your input
Old May 3, 2006 | 03:04 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Only align it when you need it. Notice things like uneven tire wear, or the most obvious of it pulling to one direction when you let go of the steering wheel.
Ive only aligned mine once in the 6+ years i've had it, and that was because i nailed a huge pothole.
I hear that the C4's have one of the best alignment's ever (i know im not using the proper term here, but you know what I mean)... from almost everyone I have ever talked to about alignment, you can drive off a cliff and it still will drive straight afterwards.
Old May 3, 2006 | 03:09 PM
91vetteboy's Avatar
91vetteboy
So far I have over 30k on my tires. No signs of uneven tire wear yet. All depends on the driver & type of roads you roam.
Old May 3, 2006 | 06:16 PM
aminnich's Avatar
aminnich
you can drive off a cliff and it still will drive straight afterwards.[/QUOTE]
Yes, but don't drive off a cliff. Some kid in a decalled-up ricer will try to pass you on the way down.
Old May 3, 2006 | 06:23 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
with all the wait-for-an-event posts above.
To 4 Wheel Alignment: How Often?
