Hope the forum can help me. While looking for a rear speaker amp for my 92 vert I have hear that a rear is 50amps and the fronts are 40 amps. Thanks JC
guess the ? is there any differents from a front amp and a rear amp as well on a vert or a coupe. Thanks JC
I'm not sure I am understanding your question. I think you are saying, "is there any difference between the front amps, and the rear amps. The answer is yes. The power is the same, but the "equalization" is different. The front speakers have more high end (frequency than the rears). But the rears, have more low freq. Power output is measured in watts. I believe they rate them at fifty each. I know they have 4 FET outputs, but it is no 50 watts. but what they are putting out is pretty clean. Providing the capacitors haven't dried out. Hope I have helped. As far as if the amps in a coupe are different than a vert. I don't know, haven't had the experience on that part. But I would bet they are the same...
Thanks for the info. Been told there is a deferents between a coupe rear amp and a verts rear amp. Just making sure before I buy one to replace my rear amp on my vert. JC
That does make sense, as the acoustics would be way different between the two...
That's why when trying to buy a amp on ebay they can't give me a anser yes or no. So that why were all here, right...Thanks again I'll just keep listing for all these replys
I have a 92 coupe...I replaced the head unit and speakers and kept the factory stuff...let me check when I get home tonight what wattage and model # they are if you are still interested.
jctoy -I haven't heard what your problem you have yet. Why do you want to buy another speaker amp. Are you up-grading or trying to fix a problem that you are having. The amps can be fixed if thats where you want to go.
Check this post for repair information. There is an account of my own experience and problem resolution as well as othe links with pictures and schematics and repair procedures of the amps. Some is technical info but there also is a how to do it info if you fit the stated problems.
I am looking to replace it because it's not working. The speaker is find and it is the amp that needs to be repair or replace. Found a guy that sell amps on ebay for $ 75.00 but can't find out if there are any different on front and rears for a 92 vert . Coupe rears are different as well I have heard so they won't sound the same either. Thanks for your info but for 75.00 it seem to be a easy fix for the price and my time. Back on the road but will check back later, Thanks Forum
Is it completely dead, no audio. Or makes some kind of noise. Are you at least sure that is it the amp and not the radio or something upstream from the speaker that would drive it. Just want to make sure you are going in the correct direction.
I did switch rear right and left speaker and amps. For sure it's the amp.There a slight hiss with this amp but no music. Thanks JC
