Put key in ignition..donot turn "on". Hold door button until you get the door opening sequence you want. Sometimes it takes a few shots to get it right.
Well as long as we are talking about it... my fob is acting kinda funny. When I first got it everything worked 100%, but now for some reason (just a few days later) the passive works just as it should, but NEITHER of the buttons work!! Is that a battery issue maybe? I dont understand why the passive would work but not the buttons if the battery is low, unless it uses less power..
Jet Jock, this was my 1st post here. I can understand how there may have been others tho.
bluedevil99, good luck with yours. Could you have dropped it and the buttons become mis-aligned?
Vette owners rock
Well I actually stopped by radio shack and picked up a new battery, and the whole thing works better (buttons included) It appears that with low battery the passive works normally, but the buttons lose all their range.
" OH MY GOD!!!! It worked! I could kiss you all over!!!!
Why on earth have those MORONS @ the parts department been telling me ALL those ^$@#!$^%#@!! fobs were bad!!???
The answer seems obvious, the MORONS are suckering you into coming back! I bet they were hoping for a
Red Dwarf!!! HOLY $HIT!!!!! I just went out with my manual and re-programmed again. Set the fob 10 ft away and then bring in to range, yada, yada, yada. Didn't work
SO, I try your "put the key in the ignition, don't turn on and press the door button" OH MY GOD!!!! It worked! I could kiss you all over!!!!
