Fuel Filter Question
Old Jul 8, 2006 | 07:51 AM
Billy Stargazer's Avatar
Billy Stargazer
Default Fuel Filter Question
I will be changing my fuel filter one of these days. (87 Coupe) I have read tips before on relieving the fuel pressure. One said to remove the fuse and crank her till the pressure is relieved. Now I just read where all you have to do is depress the schrader valve on the fuel rail (using a rag and glasses to prevent spray and spillage) This seems quite simple. This would appear to be much easier than removing the fuse. Comments from anyone who has done this would be appreciated.
Old Jul 8, 2006 | 08:22 AM
SS409 425HP's Avatar
SS409 425HP
I used the schrader valve method on my '87 coupe. Just make sure the engine is cool and you have rags ready to catch the fuel. I changed both filters (my car had two, one for the supply and one for the return fuel). Even after bleeding the fuel pressure off at the schrader valve, you will still get quite a bit of residual fuel out of the line when you loosen the fittings at the filter. I thought the fuel line was siphoning from the tank at first, but it finally stopped dripping after a few minutes. I bought AC Delco filters from my local parts store.
Supply filter p/n GF 481
Return filter p/n GF 157
Old Jul 8, 2006 | 08:23 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Pull the pump fuse while car is running. It is easier, safer and cleaner than bleeding the pressure at the schrader valve.
Old Jul 8, 2006 | 08:45 AM
RRT vette's Avatar
RRT vette
100%
Billy Stargazer
Thanks for the quick replys!
Old Jul 8, 2006 | 09:01 AM
Jet-Jock's Avatar
Jet-Jock
To make the replacement a little easier, get the tool to release the quick-release connections on the in/out lines and pull the whole assy with filter out. Replace filter and drop the whole assy back in.
Remove the bolts along the passenger rail about a half dozen, the release the upper bolt to the frame then disconnect the line and the lower bolt. Otherwise you get fuel on you getting to the upper bolt.
Use nitrate gloves. Fuel is nasty on the skin.
Old Jul 8, 2006 | 09:04 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Originally Posted by RRT vette
100%
So do i
Old Jul 8, 2006 | 09:45 AM
jrp's Avatar
jrp
Something rubbed me the wrong way about intentionally letting the engine starve for fuel, so I used the valve on my first try (still need to finish the job after reading a few helpful hints).
1) It still took a long time for the spillage to stop once I disconnected one end of the filter. It was a small flow, but a real pain to deal with.
2) Some fuel got onto the motor from the valve, and the residue caused a very strong odor after I drove it. I thought I had a leak at first and was quite concerned when the garage stunk of gas all evening.
Next time, I'll be pulling the fuse.
Old Jul 8, 2006 | 09:54 AM
Casethecorvetteman
Technically youre not driving it while youre letting the presure out with no fuse (i hope youre not ever planning on trying to anyway), so youre not really starving it.
Old Jul 8, 2006 | 10:34 AM
Jet-Jock's Avatar
Jet-Jock
Another thing to consider is plan to do it first thing in the morning if you can when the Vette has sat overnight. When I did mine, I wanted to run it up on the ramps so I put them up ran the vette up, then pulled the fuse started it and let it run until it died. Removed the gas cap and when I did the service in the morning I barely got the rag damp from excess.
For a few bucks at the local auto parts, you can get a fuel pressure gage with relief so you can vent the excess fuel to a container. Much better way of doing the service.
Old Jul 10, 2006 | 10:42 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
100%
Works fine and is faster, too.
Old Jul 10, 2006 | 01:53 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
I pulled the fuse while the car was running to relieve the pressure. but after removing the filter, gas kept coming out and wouldn't stop. The gas was siphoning from the tank, so i had to disconnect the fuel hose from the tank to stop it. The filter was a major pain to change, i don't look forward to doing it again.
Old Jul 10, 2006 | 03:31 PM
scott89's Avatar
scott89
Raising the front end helps alot before you pull the fuse of depress the schrader valve.
Old Aug 5, 2006 | 02:36 PM
MR.LT1's Avatar
MR.LT1
tool is easy to use? and can I get it at local auto parts store or is it a GM only part?
Old Aug 5, 2006 | 03:12 PM
Jet-Jock's Avatar
Jet-Jock
Yep, I got mine at CarQuest. It's a set of six tools. They are plastic collars that fit over the fuel line and press into the fitting to release it. Very simple. You pull the dust covers off to access the quick disconnect.
Old Aug 5, 2006 | 03:19 PM
MR.LT1's Avatar
MR.LT1
front already up in the air, I appreciate the info Jet..I would of never thought of that idea of pulling out the whole assembly to change fuel filter..when I saw the filter underneath I was like forget that its a nightmare...now I have hope..
Old Aug 5, 2006 | 03:46 PM
Jet-Jock's Avatar
Jet-Jock
... wish mine was a Ruby, I luv that color.
To Fuel Filter Question
Old Aug 6, 2006 | 08:36 AM
Billy Stargazer
Looking at the fuse box I see no pump fuse. According to the Helms manual it is located behind the Driver Information Center, and not in the fuse box on the right side. Is this correct?
Old Aug 6, 2006 | 08:41 AM
Jet-Jock's Avatar
Jet-Jock
Another option is to let it sit over night with the fuel cap released. Don't put the key in and turn it to RUN until you've disconnected the battery as that will re-pressurize it. Anyway, most of the pressure should be bled off and you should only get a little bit of fuel out of it.
Old Aug 6, 2006 | 09:09 AM
RRT vette's Avatar
RRT vette
The fuel pump fuse on my 86 doesn't say FP it says FR. It's a 10 amp (red) fuse in the lower right quadrant.
