C4 Over heating
Old Jul 23, 2006 | 02:29 AM
Sirwilliam1229's Avatar
Sirwilliam1229
Default C4 Over heating
I have a rebuilt engine (less than 3000 miles), that over heats. I have flushed the cooling system, checked both fans, replaced water pump, replaced thermos stat, fan switch, radiator cap, and the fan relay. I have also added some 20 degree below to the cooling system. But, when I use the A/C, the temp. quickly easies up the 240 degrees plus. What have I missed, other than checking the timing? Could the timing cause that much of a heating problem? When it's a 100+ degrees outside, the car runs fine, until I use the A/C.
Old Jul 23, 2006 | 08:17 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Maybe the compressor or pulley is is applying extra drag for some reason.
Old Jul 23, 2006 | 09:13 AM
RRT vette's Avatar
RRT vette
I don't know what year vette we are taking about and profile is blank so the info I give will be general. Make sure the area is clean between the radiator and A/C condensor. Make sure all the air is out of the coolant system and that the fan(s) is/are working and at what temp it/they come on. If the timing is off enough it can make an engine run hot. If you question the timing, double check it to see where your at and make sure the distrubitor bolt is tight.
Old Jul 23, 2006 | 12:18 PM
toolbox's Avatar
toolbox
The first question you need to ask is "is it truely over heating? I kno the cooling fan doesn't come on in my vette until 255.
Also 212 is not overheating. we're talking a closed pressurized system.
Which allows for much higher temps.
You say overheating does that mean boiling over? Stuck on the side of the road?
Or I think it's running hot?
Have you replaced the temp sending unit? It may be just that easy
Old Jul 23, 2006 | 12:59 PM
RRT vette's Avatar
RRT vette
WOW, 255*
Old Jul 23, 2006 | 01:29 PM
vader86's Avatar
vader86
If the overheating is AC related, you'd probably be best asking SunCr
I believe if the pressures are too high then extra heat would be imparted to the condensor.
any other overheating solutions are on my website
Old Jul 23, 2006 | 02:24 PM
morgan_kane's Avatar
morgan_kane
Does it overheat in highway? Or only in low speeds/traffic?
Does the fan start? If ac is on, fan should run when car is not moving.
Old Jul 23, 2006 | 02:32 PM
HG's Avatar
HG
OK, here is my .02. RRT made a good point about the area between the radiator and condenser. You can get a ton of junk in there. My 93 has an open space at the bottom to check but the L98's were sealed. One thing I did read about the LT1 is the correct thermostat. If it is a 92-96 just any thermostat won't work. There is something special, can't remember what , in the design of the thermostat for an LT1.
Old Jul 23, 2006 | 05:00 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Rather than everyone shooting in the dark, so to speak, why don't you give us a few more details about the car. Mileage, year, motor, modifications, where you are with the car (geog), trans, condition, what else you've done/tried, thermostat, etc. Thanks.
Old Jul 23, 2006 | 05:20 PM
Maui's Avatar
Maui
St. Jude Donor '08
C4's definitely run hot. Seems to be an ongoing issue for many of us. Mine runs hot if the ac is not on due to the lack of aux fans when the ac is off.
Old Jul 24, 2006 | 03:05 PM
ZR_Don's Avatar
ZR_Don
CI 2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '06
Have you ever pulled the raidator out of the car? The C4's are known for sucking up all kinds of debris. You will have all kinds of sand, leaves, animal fur in even a low mile car. Reasearch the archives as there has been plenty of posts about flushing the outside of the radiator. My ride has 40K on it and it needed too be done. Good luck!
Old Jul 25, 2006 | 11:08 AM
Sirwilliam1229
I have 164K on the car, and I rebuilt the engine less than 3000 miles ago. I have a 160 degree thermo stat, I have not pulled the radiator, ummm what else? The car is a 1989 with an automatic trans, Hypertech chip, borla exhaust, K&N filter with an open lid, and a useless air foil. I live in Southern California, where the temps. lately have stayed between 102-117 degrees.
Old Jul 25, 2006 | 11:10 AM
Sirwilliam1229
Both fans work.
Old Jul 25, 2006 | 06:35 PM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
Do Your Analog And Digital Temps Match?
My Guess Either Junk On The O/s Of The Radiator, Or Junk Loose In The Inside Of The Radiator. Pull That Baby And Clean, Or Replace.
Old Jul 25, 2006 | 07:18 PM
BADDUCK's Avatar
BADDUCK
That may be it. You have a bunch of miles on the radiator if it's original.
Old Jul 25, 2006 | 07:21 PM
96GS#007's Avatar
96GS#007
Not unless you reprogrammed the ECM or PCM.
Old Jul 25, 2006 | 07:46 PM
vader86's Avatar
vader86
You can read the first link on my website and go through the troubleshooting procedure.
To C4 Over heating
Old Jul 26, 2006 | 08:38 AM
kguillen's Avatar
kguillen
Cruising
Before you decide that it is overheating, you should compare the digital sensor output with the analog guage output. They take readings from two different locations on the engine. Second, when your A/C is on you should notice thgat your second cooling fan runs, if it doesn't this could be your problem.
Old Jul 26, 2006 | 11:04 AM
rick lambert's Avatar
rick lambert
All good advice. As for ToolBox and his 87, you've got problems. The aux. fan on an 87 should be comming on at around 236-238, and if you're hitting temps of 255, hope your using synthetic oil, and start saving money for a new engine.
Old Aug 5, 2006 | 05:56 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
My '91 has been running 240*~ 250* on 100* days.
I've cleaned between the condensor and the radiator, removed the radiator and cleaned it.
It's full of water. It has ALWAYS run hot in the summer.
My '84 typically runs 220*~230* on the same day. I've done all the same cleaning to the radiator on it as well.
It seems the cooling system is marginal at best.
Both of them run hotter than I'd like but... I just don't worry about it anymore.
1) I've run Water Wetter .... NO Change in temps.
2) I've run 40? Below ...... No Change In Temps.
3) I've run Greased Lightning Cooling System Treatment....No Change In Temps
4) I've run 20% Coolant & 80%* Water..... No Change In Temps
