Keyless Entry Remote
Old Aug 11, 2006 | 02:03 PM
honda hunter's Avatar
honda hunter
Default Keyless Entry Remote
Is there anywhere to get replacement pieces? The plastic is broke and I'm hoping I wont have to buy a new one.
Old Aug 11, 2006 | 04:22 PM
Jet-Jock's Avatar
Jet-Jock
Where did it break? If its the little plastic tabs that hold it together, mine broke too. What I did was use some superglue and put a drop on each side squeeze it together until it sets. When I need to replace the battery a small blade screwdriver will pop it back apart.
Old Sep 16, 2006 | 08:04 PM
94bluedevil's Avatar
94bluedevil
Default Programming Instructions
I have a 1994 corvette coupe.
does anyone know where i can find the programming instructions for my remote, i bought a new one on ebay.
Old Sep 16, 2006 | 10:11 PM
papidos's Avatar
papidos
Programming instructions should have come with the unit from where you purchased it. If not a dealer will do it for about 20 bucks.
PS You're threadjacking. Not Nice.
Old Sep 16, 2006 | 10:21 PM
Jet-Jock's Avatar
Jet-Jock
Programming:
Separate the key from the transmitter fob. Place the transmitter greater than 10 ft.
Key in the ignition to the RUN position.
Push the TRIP ODO button and release.
Push the TRIP ODO button again and hold for 5 seconds.
Within 5 seconds of that push and hold the INFO button for 10 seconds.
The Passive Keyless Entry telltale lamp on the DIC will come on continuously.
Turn the key to the LOCK postion but leave the key in.
The Passive Keyless Entry telltale lamp will now begin flashing.
Bring the transmitter into range, once the system sense it program that frequency of that transmitter and the lamp will change from flashing to continous to indicate it is done. (Only takes a second.)
Once the lamp is continous, remove the key.
NOTE:
Driver's door open press and hold the door button on the transmitter to cycle it from passive to non passive (turn it off). The locks will cycle.
With the driver's door open and the key in the ignition, pressing and holding the door button on the transmitter wil set whether just the driver's door is auto unlocked or both doors are auto unlocked. The locks will cycle inidicating one mode or the other while holding the button down.
Both cases it's about 3 second hold for it to activate the function change.
Old Sep 17, 2006 | 12:23 AM
94bluedevil
i just programmed my keyless entry. From what i read you can't unlock the doors from the outside with the DOOR button on my remote?
it says it only opens the passenger door. So u need the passive keyless entry to be on to unlock the doors?
Old Sep 17, 2006 | 12:45 AM
ruby9246's Avatar
ruby9246
St. Jude Donor '03-'05-'06-'07-'08
You can program the PKE to open only the drivers door or both.
Old Sep 17, 2006 | 09:43 AM
Jet-Jock's Avatar
Jet-Jock
If it is in non-passive mode the transmitter fob door button will open the passenger door (but not the driver's door) and the hatch button will open the hatch glass. UTD (universal theft deterrent) system is still armed when you lock and shut the doors in non-passive mode. You need to use the key to unlock the driver's door in order to disarm UTD.
If it is in passive mode it will open the driver's door or both depending on which mode you set (as described above in Note).
Old Sep 17, 2006 | 09:54 PM
Rathbone's Avatar
Rathbone
be careful not to buy the part I did. It looked like a replacement case that you could put your PKE guts into, but it wasn't. It was just a paper thin cover to go over your existing PKE to change the color of it. I spoke to the seller over the phone and they didn't bother to correct my misunderstanding.
To Keyless Entry Remote
