Is there any where i can find a diagham for the vac. lines that run under the TPI? while changing my thermostat, some hard lines came unplugged in the area right behind the thermostat and under the plenum.
I just want to make sure I plugged them to the correct spot. Because now it just doesn't seem to idle quite right. It also seems to have a flat spot when you first give it gas. I also put in new plugs and wires.. LIKE MY WIFE ALWAYS TELLS ME--IF IT AINT BROKE, DON'T FIX IT. BUT I NEVER LEARN ! Any help would be great
THANKS
Reason: change in title
