Ruby Red paint code (WA****)?
Old Sep 7, 2001 | 01:05 PM
Midnite 88's Avatar
Midnite 88
Default Ruby Red paint code (WA****)?
Sorry, to do this to you guys. I know the RPO code is U68. The GM guys can't find the match for this color in thier books.
they need a color code that starts with a (WA). On my '88 the paint code is under the console lid on the bottom of the RPO sticker. Mine says WA8555 blk/clr.
TIA Mike.
You can E-mail me at mike_ruel@harte-hanks.com
Thanks again.
Old Sep 7, 2001 | 02:51 PM
Scoob's Avatar
Scoob
Default Re: Ruby Red paint code (WA****)? (Midnite 88)
Doh! Never mind
[Modified by Scott 89, 1:53 PM 9/7/2001]
Old Sep 7, 2001 | 03:02 PM
Scoob's Avatar
Scoob
I found this bit of info for you.
http://www.40thregistry.com/discussi...2/00000213.htm
You can post a question here if that doesn't help you:
http://www.40thregistry.com/discussion/index.htm
Old Sep 7, 2001 | 03:42 PM
rubyred93's Avatar
rubyred93
Default Re: Ruby Red paint code (Scott 89)
Just as a side note ... there were NO variants in the '93 Ruby Red paint. This should make it much easier. Also, DuPont makes an excellent match to the Ruby Red. I had a louver panel replaced using the DuPont System - outstanding match! :yesnod:
Old Sep 7, 2001 | 03:49 PM
Scoob's Avatar
Scoob
Default Re: Ruby Red paint code (rubyred93)
Right. I'd be willing to bet that the confusion experienced in the link I posted above was probably related to the fact that for the '89 and '90 model years code 68 was called Dark Red Metallic. Then the code disappeared until 1993 where it was called Ruby Red.
This is a great example of why you need the W codes to be sure you get the right paint match. The RPO codes are more like marketing codes than paint codes.
Old Sep 7, 2001 | 05:54 PM
Mikez40's Avatar
Mikez40
WA213A
Old Sep 7, 2001 | 06:37 PM
silver-eagle's Avatar
silver-eagle
I have to ask... What's Triple Ruby Red?
-John
Old Sep 7, 2001 | 10:06 PM
rubyred93's Avatar
rubyred93
Default Re: Ruby Red paint code (silver-eagle)
John -
"Triple" refers to three aspects of a convertible. They are : 1. The top color 2. The interior color 3. The body color
Since the 40th Anniversary cars are Ruby Red in all three areas, they are considered Triple Ruby Red. If someone had a convertible that had a white top, a white interior and a white exterior, it would be considered triple white. The same would go for a black convertible with all three areas being black - triple black, etc.
Hope that answers your question.
Old Sep 8, 2001 | 12:29 AM
Midnite 88's Avatar
Midnite 88
Default Re: Ruby Red paint code (Mikez40)
Thanks for all the help guys. My car is actually black but, I wanted to do some contrasting scheming with the "Dark Ruby Metallic" (thats what the Tech at GM told me the color is called when gave him the "WA" number)
I just love that color. I almost bought a Ruby Coupe before I found "Midnite".
Thanks again, Mike.
To Ruby Red paint code (WA****)?
