Code 15
Old Aug 14, 2006 | 02:05 PM
Demonic85's Avatar
Demonic85
Default Code 15
After adjusting my valves on my '85, the car gave me code 14 and 15 on startup. I replaced the connector and wiring to the coolant sensor and now I'm still getting code 15. The car runs around 400 rpms and will stall until it gets warmed up if I dont give it some gas. It feels like it has no power and its missing. My dad said it sounds like the timing is off. So I bought a timing light, but i've been told code 15 could mean a bad ECM. I was wondering if anyone else has experienced a similar problem and has advice before I go and waste money.
Old Aug 14, 2006 | 03:15 PM
Demonic85's Avatar
Demonic85
ttt
Old Aug 14, 2006 | 08:06 PM
nutz4c4's Avatar
nutz4c4
code 15 = high voltage to the CTS. You seem to be having alot of trouble with timing this car.What condition is your timing chain in?Next time you have the spark plugs out pop off the distributor cap.Note where the rotor is pointing,then turn the balancer one direction until the rotor moves a little,then turn the balancer the other way.If the rotor does not move right away you have a strectched timing chain or lost some nylon off the cam gear. A little strecth is ok but you might be surprised at just how far it can stretch and the car still run. I have seen them wear thru the timing cover and still run.
Old Aug 14, 2006 | 11:20 PM
Demonic85's Avatar
Demonic85
The timing chain is in good shape, the engine and rotor turn and there is no slack. I just cant figure out if its the coolant sensor, the ECM, or the timing. I dont want to throw parts at it and end up wasting a bunch of money.
Old Sep 27, 2006 | 10:28 PM
Googan's Avatar
Googan
Did you ever figure out what was wrong with your car? I'm getting the same code 15 right now.
Old Sep 28, 2006 | 07:10 AM
RRT vette's Avatar
RRT vette
The "ECT" (Engine Coolant Temperature) sensor or CTS (Coolant Temperature Sensor) monitors engine coolant temperature and sends the ECM a resistance signal that affects the ECM control of fuel mixture and ignition timing. This sensor, located in the front of the intake manifold next to the CSV switch, can be ohmed. It can be ohmed mounted in the intake manifold or outside in your hand. This is a temperature sensitive sensor. Buy using a ohm meter and touching the two terminals on the sensor with the ohm meter leads you will get a number. This number will vary with temperature. The colder the temp the higher the number and vise versa. Use the FSM to get the answer or post back the ohm's it read and the temp (engine or outside) the sensor was. Say at 70*f the sensor should read 3,400 ohms. Check the connection.
Old Sep 28, 2006 | 09:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you follow the flow charts, it will shorten your list of possible problem parts.
http://members.shaw.ca/corvette86/Code%2014.pdf
http://members.shaw.ca/corvette86/Code%2015.pdf
Old Sep 28, 2006 | 10:33 AM
Demonic85's Avatar
Demonic85
Oh yeah it was the coolant temp sensor under the throttle body.
Old Sep 28, 2006 | 10:50 AM
RRT vette's Avatar
RRT vette
4Ever21, I didn't realize this was started over a month ago. Maybe 84vette967 can use this info.
Old Sep 28, 2006 | 10:54 AM
SunCr's Avatar
SunCr
If you haven't found the problem, 15 means that the ECM is seeing and impossibly high temp from the sensor - about 300 degrees. More likely than not, the signal wire (yellow) is grounded somewhere between the sensor and the ECM - particularly if you've allready replaced the pigtail. Confirm it by disconnecting the harness from the sensor. That simulates a 14, but if the 15 remains, you'll need to troubleshoot the yellow wire back to the ECM.
Old Sep 28, 2006 | 05:39 PM
Googan's Avatar
Googan
The engine seems to be running normal, but the other monrning the check engine light came on for a minute and then went off. Maybe it was just loose connection or something.
To Code 15
