Help! My problem is back!
Old Sep 24, 2006 | 11:33 AM
photoguy's Avatar
photoguy
Originally Posted by trulytex
There is also a bank of Relays under the drivers' side of the dash on the left side of the steering column (on my 1990). One of these Relays is for the VATS Starter Disable. They can get weak over time. I had the same problem as you and I replaced this Relay. It solved my problem, but I decided to bypass it also. I called Gordon Killebrew and he told me the steps. I posted them about 2 months back. Good Luck - VATS can break your heart!
Can you forward the disable instructions? I did a search and can't find anything.
Thanks.
