what does sys mean
Old Nov 5, 2006 | 01:54 PM
dragracefan's Avatar
dragracefan
Navigator
Default what does sys mean
In the center of the dash in the information area it keeps flashing sys every so often I'm guessing the fuel econ unit is going bad. anybody else run into this?
Old Nov 5, 2006 | 02:43 PM
scranage's Avatar
scranage
I think it generally means a communications problem between the ECM and CCM, but I'm sure someone will jump in if I'm wrong.
Old Nov 5, 2006 | 02:48 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
Yes, but you'll need to pull codes to narrow down what's going on with your car.
Old Nov 5, 2006 | 03:33 PM
bogus's Avatar
bogus
It could mean a number of things... do you have an aftermarket stereo? How old is the battery?
Check this out... C4 Guru - Reading CCM Codes 1992/1993
This is focused on the 92/93 years, but others are close.
Old Nov 5, 2006 | 03:36 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i think its electrical
Old Nov 5, 2006 | 03:41 PM
bogus's Avatar
bogus
don't jump to conclusions... there is a lot that can be wrong... but we need to codes before we can make an assessment.
Old Nov 5, 2006 | 10:07 PM
Dads90's Avatar
Dads90
Default Sys display
Mine has done it on ocassion. But it does it right after start up, flashes three times and goes to its regular function. Nothing seems to be affected, all instruments seem fine.
Old Nov 5, 2006 | 10:11 PM
Hotred94's Avatar
Hotred94
Generally it means electrical system problems. This could be battery problems, alternator problems, or that an aftermarket stereo has been put in and is not returning the right resistance value.
Old Nov 5, 2006 | 10:46 PM
dudman's Avatar
dudman
I had the same problem last week. It turned out to be a blown fuse that feeds the interior door lights. However, as the others say, it can be a lot of things. Good luck.
Old Nov 6, 2006 | 01:28 PM
Atok's Avatar
Atok
It means the CCM has a code stored. Normally this is an electrical problem, and in most cases something minor. Check the codes in your CCM and it'll tell you what's wrong.
Old Nov 6, 2006 | 04:12 PM
behnevette's Avatar
behnevette
Originally Posted by bogus
It could mean a number of things... How old is the battery?
It's a good chance it's just the battery.
Old Nov 6, 2006 | 08:31 PM
JackVM's Avatar
JackVM
Great PDF file, but where is the connection located where you read the codes? Under hood, dash? Thanks.
Old Nov 7, 2006 | 11:35 AM
IrishJoker's Avatar
IrishJoker
Under the dash on the driver's side.
Old Nov 7, 2006 | 08:43 PM
t-93's Avatar
t-93
I have recently been having the same problems, I saw the SYS light up while driving down the road, and the interior lights will not go off, I checked the fuses to find the fuse for the doors and under the dash was blown, I pulled another 5 amp fuse from another slot and plugged it in and all of the interior lights were on and would not turn off. I read that there are CCM codes to read, do you have to have a special electronic device to display these codes? What should I do....? for now I am pulling the fuses for the interior lights until I can fix it. One other note...two weeks ago I left the key in the ignition turned on while waxing....to say the least the battery was dead three hours later, I hooked up a trickle charger and left it on for one day and have had no problems with battery since, but the problems started after that, exactly when I can't say.
Old Nov 7, 2006 | 11:56 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
All you need is a paper clip. see the C4 Guru CCM Codes tech tip link posted by bogus.
Old Nov 29, 2006 | 06:47 PM
Redhook98's Avatar
Redhook98
I have the exact same problem. Did you find a solution?
Old Nov 30, 2006 | 06:41 AM
beachrover's Avatar
beachrover
Check out the post by Bogus, it will lead you to the problem and fix!
Old Nov 30, 2006 | 05:49 PM
JazyJeff13's Avatar
JazyJeff13
Mine was the battery went bad
Old Nov 30, 2006 | 06:21 PM
MR.LT1's Avatar
MR.LT1
My car was sitting for like 2 weeks I started it and the SYS started flashing.... charged up the battery with my drip charger and SYS gone.....
To what does sys mean
