windshield wipers
Old Jan 15, 2007 | 11:23 PM
corvettpilot's Avatar
corvettpilot
Default windshield wipers
Looking for a fix for my left windshield wiper. It travels to far on the outbound swipe. This has caused some scrapes on the window post on that side. Anyone encounter this problem? the fix?
Old Jan 16, 2007 | 12:05 AM
94z07fx3's Avatar
94z07fx3
I bought new blades for my Wife's 92 tonight. I held up one of each of the different vendor's blades the book said fit the car. The longest one was an inch longer than the shortest one. The ones I bought were Tricos and had two mounting holes to choose from. If I had installed the blade using the bottom hole it would have put the tip on the windshield frame. I used the top hole and all is well.
If your blades are these, try using the other hole.
Does the left arm on your car park tightly next to the right one? If it doesn't you could consider removing the arm and replacing it a few degrees to the right. The arm is held onto a splined pin by a retaining clip and is under pressure from the springs.
Old Jan 16, 2007 | 12:16 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Turn on the wipers and then turn the key off with the wipers all the way up There is a nut on the wiper where it pivots that will allow you to adjust it
Loosen the nut move the arm and tighten the nut
Sometimes people work on them dont know how they fold up and damage them
At worst you may need an arm
I hope I understand you correctly, when the wiper goes up it hits the A-pillar on the driver's side--- Right?
Old Jan 17, 2007 | 10:41 AM
corvettpilot
Yes, that is what is happening. Another problem I have is the two wipers snag onto each other during use.
Old Jan 17, 2007 | 11:19 AM
c4cruiser's Avatar
c4cruiser
Proper adjustment of the arms should solve the wiper blades hitting each other. One trick you can do is to use a smaller blade on the passenger side.
There is also a chance that there is enough wear on the various pieces that the sweep of the arms is getting wider. The busings on the components may be worn to the point where the slop is allowing more movement.
If you ever have to replace the arms, use arms from a 95-96. The arm was redesigned to a lower profile and will allow the wipers to park under the hood.
This is from the Tech Tip section: https://www.corvetteforum.com/techti...D=42&TopicID=2
Old Jan 19, 2007 | 02:59 AM
corvettpilot
Much thanks C4 Cruiser! I think I will try your suggestion and switch to the 95-96 style. Thanks
To windshield wipers
