I win!
Old Mar 30, 2007 | 09:55 PM
  #41
1985 Corvette's Avatar
1985 Corvette
Originally Posted by Pete K
After a few months of being down for the count, the vette runs again. This problem whooped my azz
I spent in excess of 40 hours diagnosing and rewiring the entire ignition system to discover the MSD spark/retard box was the problem.
Took it for it's first drive since the fall. Registration renewed, state inspection and emmisions exemption and it is legal once again.
Anyhow, glad to be back
Glad to hear your car is working again. You're a lot better trouble shooter than I am. I get angry just looking at a loom of wires with all those different colored tracer wires.
Old Mar 30, 2007 | 09:56 PM
  #42
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
40 hours is a bunch of time...I do not think I would/could have stayed with it for that long!
Congrats on getting back on the road again!
Old Mar 30, 2007 | 09:59 PM
  #43
Pete K's Avatar
Pete K
About 10 hours were spent actually fixing the problem by running the new harness, disassembly and reassembly. It shames me to admit it took so long, but this one whooped me bad
Old Mar 30, 2007 | 10:28 PM
  #44
Steve85's Avatar
Steve85
Cruise-In V Veteran
When I wired in the MSD box in 1993, I ran a seperate harness to the interior of the car. Using weatherpack connectors, I made the harness to allow for swapping back and forth from msd to stock ignition. This way, if I had a failure on the road, it would be easily switched back and forth as needed.
Initially, the problem was very intermittant. This sucked up 1/2 the time.
A few years ago, I decided that the retard box would make a nice addition. It allows a predetermined amount of timing to be pulled back when the NOS is armed.
To be honest, I forgot about this box, and there is no known way to test it.
I suspect that there will (hopefully) be no next time. I have the bad msd boxes screwed to my garage wall of shame.
There simply isn't anything more frustrating. You spend the majority of the time trying to duplicate the failure and it's hardly under testing friendly conditions. Then you start playing jedi mind tricks on yourself on what it could and couldn't be and gloss over the most likely because if you check that, and it doesn't fix it, then you are really f'd.
Kudos for sticking with it.
My last experience with this was actually a tranny related issue where the car would stall when shifted into drive or when coming to a stop...sometimes. The TCC switch (whatever locks and unlocks the converter) and everything related were checked a hundred times. If we added up the hours spent, the diag time was more than the car was worth. It was the last car I worked on professionally.
PS. this is why there is a flat rate in auto shops...you win some, you lose some.
Old Mar 31, 2007 | 11:00 AM
  #45
Bill Hetzel's Avatar
Bill Hetzel
This makes me wonder if the MSD Opti is worth the extra $120 vs. the GM unit.
Old Mar 31, 2007 | 11:03 AM
  #46
corvettekid89's Avatar
corvettekid89
Old Mar 31, 2007 | 11:04 AM
  #47
carlton_fritz's Avatar
carlton_fritz
St. Jude Donor '08-'09
Educate a newb. What is an MSD box?
Old Mar 31, 2007 | 11:06 AM
  #48
cv67's Avatar
cv67
St. Jude Donor '05
Multiple Spark Dishcharge box.
I had one that seemed pretty reliable but everyones MSD/Crane box that I knew of eventually left them stranded. Im sticking to a simple dist/coil setup.
Old Mar 31, 2007 | 11:09 AM
  #49
Pete K's Avatar
Pete K
Check post #40
Old Mar 31, 2007 | 11:17 AM
  #50
ghoastrider1's Avatar
ghoastrider1
welcome back
Old Mar 31, 2007 | 02:57 PM
  #51
carlton_fritz
Check post #40
I just read it. Is there any reason why I should want that on my '91?
Old Mar 31, 2007 | 05:12 PM
  #52
redwing76's Avatar
redwing76
The msd wires into the stock ignition. It is a single box with no other changes needed. On my car, it improved the idle, improved hold and hot starts, and gave a slight increase in gas milage. It also has a rev limiter in it. The reason I bought one back in 92 was to help improve 1/4 mile time. It did nothing to help et or mph on my 87 coupe.
Excessive moisture, vibration or heat can help kill them. My units were mounted inside the car, and in my opinion(as well as the msd tech's), it was mounted in a best possible location.
Thanks for the info, it makes sence now.
Old Mar 31, 2007 | 09:22 PM
  #53
Pete K's Avatar
Pete K
When they work properly, they do (in my opinion) make it worthwhile. I still run an ignition amplifier, but a different brand than the msd.
Old Apr 1, 2007 | 10:05 AM
  #54
carlton_fritz
I guess the slight increase in gas mileage is enough reason.
