Another Hidden Feature...
Old Apr 17, 2007 | 10:38 AM
  #41
Vette Gator's Avatar
Vette Gator
Originally Posted by c4cruiser
What's interesting is that the light housing under the back of the C4 is the same housing used for the license plate lamp on the C5. The bulb is a 194 so if the light doesn't work , try a replacement bulb.
This thread inspired me to check my 89 and I found that the bulb was burned out. Even though the exterior housing the same as the C5 license plate lamp, a 194 won't fit into the holder (the base is too wide). The under-bumper light holder takes a #24 lamp (around $1 at Autozone). Anyone want a surplus 194 lamp?
On a side note, while searching for the correct light bulb for this holder, I did an internet search for "89 Corvette undercar light bulb" or something similar. The top hit was for blue neon tubes. Hmm. Note quite the light bulb I was looking for.
Old Apr 17, 2007 | 10:43 AM
  #42
corvettedan22's Avatar
corvettedan22
Yep, got it on my 85, fixed the buld !!
Old Apr 17, 2007 | 10:50 AM
  #43
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by LT4CompYell
So, NOW are you impressed with your great car?
More and more each time I drive it, Bill!!
Larry
code5coupe
____________
I ain't easily impressed....
Old Apr 17, 2007 | 12:19 PM
  #44
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My car has a bad driving sensor. Lights will flash in the rear view mirror, then it makes honking sounds and the windows will suddenly have spare change and soda cans bouncing off of them.
Try it out some time!
Old Apr 17, 2007 | 12:26 PM
  #45
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
"Mine has it!"
"Mine doesn't have it!"
You all sound like a bunch of Star-Bellied Sneeches.
Old Apr 17, 2007 | 12:31 PM
  #46
myred86's Avatar
myred86
Since we've shed light on the lights , another "feature" if you have the old Delco Bose radio is the capability for seven station presets beyond the four buttons. To store the extra three, store like you normally would but hit buttons 1 and 2, or 2 and 3, or 3 and 4 at the same time. To use the preset, just hit the two buttons at the same time again. This is assuming that you still have the original head unit! I learned this in the Forum about a year ago.
Old Apr 17, 2007 | 12:54 PM
  #47
rocco16's Avatar
rocco16
Originally Posted by myred86
if you have the old Delco Bose radio .... hit buttons 1 and 2, or 2 and 3, or 3 and 4 at the same time.
Larry
code5coupe
__________
Old Apr 17, 2007 | 12:57 PM
  #48
CentralCoaster
A lot of people don't realize pushing the door lights on older C4s make them stay on.
And that there's hatch pop switches in the end of both doors, at least on some years.
Hell, it took me 6 months to figure out there was a cargo shade.
Old Apr 17, 2007 | 01:02 PM
  #49
rocco16's Avatar
rocco16
It took you almost that long to figure out there was a tachometer.
(just can't help myself)
Larry
code5coupe
___________
Old Apr 17, 2007 | 01:28 PM
  #50
Goldcylon's Avatar
Goldcylon
Originally Posted by 94ZR1
Anybody know what years had this?
Both my L-98 90 coupe and 91 ZR-1 has this option. I think 93 was the last year but not sure.
Old Apr 17, 2007 | 01:57 PM
  #51
CentralCoaster
Larry
code5coupe
Have you stumbled across the ASR or tire valve stem feature yet by chance?
Old Apr 17, 2007 | 02:56 PM
  #52
78pacer's Avatar
78pacer
My '78 has a spare tire light.......and it works!
Mike
Old Apr 17, 2007 | 06:51 PM
  #53
TA's Avatar
TA
Originally Posted by joecaver
I'll have to try that and see if my 90 will do it.
I believe it only works on 94-96 cars.
Old Apr 17, 2007 | 07:19 PM
  #54
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Originally Posted by MarkC4
They should call that the Florida alarm!
Huh? NOBODY uses their turn signals in Florida (except maybe me). In fact, if you do, I'm pretty sure the police can stop you for suspicious behavior...
Old Apr 17, 2007 | 07:23 PM
  #55
tobijohn's Avatar
tobijohn
Bench Racer
...And that there's hatch pop switches in the end of both doors, at least on some years...
I had my 88 coupe for three years and never knew that. Eleven years later, I accidently discovered it on the 96 LT1...:o
Old Apr 17, 2007 | 07:53 PM
  #56
95wht6spd's Avatar
95wht6spd
Originally Posted by drmvette86
where are the secret compartments in the door?:o
We can't tell you, they are SECRET! Plus we would have to kill you....
Old Apr 17, 2007 | 08:38 PM
  #57
92LRC's Avatar
92LRC
So does this mean that if I turn on the interior lamps while I'm driving my 92 that I will also light up underneath the rear end?
That would almost be like setting up a neon kit.
To Another Hidden Feature...
Old Apr 17, 2007 | 08:49 PM
  #58
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Light travels faster than sound. That's why some people appear bright until you hear them speak.
Old Apr 17, 2007 | 08:56 PM
  #59
champs65's Avatar
champs65
Originally Posted by dallasknight
does my 85 vette have one?
It does have the spare tire light, though.
Old Apr 18, 2007 | 09:25 AM
  #60
Desert1957's Avatar
Desert1957
Default Spare tire light part#?
Most of us know by now about the secret compartments in the doors, the spare tire light, and the hatch releases.
I found another one this weekend.
Driving down the freeway, en route to a Forum GTG, and I hear the ding...ding...ding of the warning chime. You know, the one that goes off if you pull the key out of the ignition without turning off the lights?
What the heck....?? My lights aren't on and I'm running 80mph...?
After spending a panicky 30 seconds looking for problems and finding none, I notice my turn signal has been on since a lane-change about two miles back.
Turned the signal off and the chime went silent!!!
I never knew that.
Larry
code5coupe
__________
Larry,
Thanks for the info about the spare tire light , just thought I would check my 92.
Check this out my 92 has the mounting bracket with the screws half way out , the wiring and socket with a burned out bulb , but no housing or lens , go figure.
Someone must have removed the housing assm. and never reinstalled it.
Just wondering if anyone has the part number for the lens and or the bulb housing , thanks in advance.
Desert
__________
I ain't easily impressed....[/QUOTE]
