Oct 18, 2001 | 01:13 AM
Alluminum Cleaner.....Before and After
No commercial posts from non-supporting vendors.
Oct 18, 2001 | 11:28 PM
Re: Alluminum Cleaner.....Before and After (KNCRSR5R)
how much is this stuff???
Oct 19, 2001 | 12:58 AM
Re: Alluminum Cleaner.....Before and After (bogus)
Looks awesome, Erik...........now time for some cross drilled rotors to really finish off the look :cheers:
Oct 19, 2001 | 01:42 AM
Looks Awesome..where do I git sum?
Bob
Oct 19, 2001 | 03:12 AM
Re: Alluminum Cleaner.....Before and After (BobMachus)
Looks great!! who sells it?
Oct 19, 2001 | 08:03 AM
Looks like a lot of elbow grease went into that as well :cool:
Oct 23, 2001 | 09:34 PM
Re: Alluminum Cleaner.....Before and After (turbota)
come on now dont keep us in suspense, Who sells it?
Oct 24, 2001 | 12:16 AM
Re: Alluminum Cleaner.....Before and After (ASRoff)
Looks a lot like the results from wire wheel cleaner or air conditioning condenser cleaner.
Does it make a lot of white foam? Burn like the devil if you have an open wound?
If the answers to the above are yes, chances are it's hydroflouric acid. Go to a detailing supply house and it's ~ 20.00 a gallon.
Mark
Oct 24, 2001 | 12:19 AM
Thanks for the replies guys!!!!
HEY ASROff.......you have mail!!!!!
Sorry about the delay guys!!!
No elbow grease on the rear suspension......a little on the front where the years of chasis grease has caked on!...and None on the Plenum!!!!
Oct 24, 2001 | 12:21 AM
HEY TA........
after finding my rotors have alot of wear....i might just do that!!!! :yesnod:
Know where i can find some good rotors that wont break the bank!!!! :seeya
Oct 24, 2001 | 02:55 PM
Quote:
how much is this stuff???Where do I get it????
:yesnod:
Oct 24, 2001 | 03:43 PM
Re: Alluminum Cleaner.....Before and After (vanduker)
Vanduker has it. Thats got to be what that is. And as long as you use it on the suspension or the intake it should work good. I'd be careful on using it on the calipers, it is acid.
Notice their claim on the distributor cover. If I had to guess, they used it on that too, but its such a lower grade of aluminum that it does that to it.
You should always test this stuff in a small area before coating the whole thing. I turned a whole intake manifold that cast iron color once (not vette) and had to break out the wire brushes and electric drill and do the whole thing.
Oct 24, 2001 | 07:02 PM
Re: Alluminum Cleaner.....Before and After (White Lightning 89)
edited - only supporting vendors may make commercial posts.
