Locks Not Working
Old Jun 14, 2007 | 11:45 AM
murraydeluxxxe's Avatar
murraydeluxxxe
Default Locks Not Working
Yesterday, I got in my 88 Vette, the automatic locks worked. 3 minutes later when I got home, they didn't. Any thoughts?
Old Jun 14, 2007 | 12:05 PM
JCD's Avatar
JCD
both sides? if so I'd guess fuses, does the 88 have the fuse panel inside the passenger door (not on the door itself)...
Old Jun 14, 2007 | 12:54 PM
murraydeluxxxe
It does have a fuse panel inside the passenger side door. I'll give that a try, thanks!
Old Jun 14, 2007 | 01:08 PM
JCD's Avatar
JCD
The bad news: if it is a blown fuse, there's probably a reason why the fuse blew, possibly a bad switch, lock solenoid, or shorted wire. If you replace the fuse and it goes again you'll have to track down the cause.
Old Jun 14, 2007 | 09:56 PM
murraydeluxxxe
Well, unfortunately (or I guess fortunately?) it's not the fuse. So the mystery continues...
Old Jun 15, 2007 | 01:29 AM
corvette1989bham's Avatar
corvette1989bham
more info needed, both locks in/op lock and unlock, any noises when you press the button? Any AFTERMARKET alarms or remote open?
Old Jun 15, 2007 | 09:00 AM
murraydeluxxxe
No aftermarket alarms. The automatic lock on both doors do not work. (The locks work manually) There is no noise when I hit the button.
Baffling.
It is as if something became instantly disconnected.
Old Jun 15, 2007 | 10:56 AM
JCD's Avatar
JCD
Now you need the Factory Service Manual...
Are you going to try to diagnose the problem yourself?
Pulling the door panel off isn't hard, but there are a few hidden screws and once you get it off you have to hold it up while you disconnect the connector for the hatch release, it's akward but not really difficult.
Old Jun 15, 2007 | 02:21 PM
murraydeluxxxe
The locks are a low priority. So, we'll see. I think I can live with it. For a while.
Old Jun 16, 2007 | 02:13 AM
corvette1989bham
a broken ground wire in either door can disable the locks . . . but thinking fuses first . . . . have you tried switches on both side of the car?
Old Jun 17, 2007 | 12:34 AM
biglou71's Avatar
biglou71
Cruise-In VI Veteran
I have a similar issue. The power lock will operate the passengers side fine, however not the drivers, nor can you move the manual lock on the drivers side. Any ideas?
Old Jun 17, 2007 | 08:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Power%20Locks.pdf
To Locks Not Working
