Water Spots
Old Jul 13, 2007 | 03:04 PM
ballertyped's Avatar
ballertyped
Default Water Spots
I can't find anything to get it off my back window, any suggestions?
Old Jul 13, 2007 | 03:39 PM
DisasterDave's Avatar
DisasterDave
Try vinegar! Apply it gentry with a mildly abraisive applicator, like maybe one of those makeup sponges out of a woman's compact (oops!, I mean, I have no intimate details of such things.) Anything like that just gently applied with vinegar in a swirling motion can be pretty effective on water spots. Good luck!
Dave
Old Jul 13, 2007 | 07:41 PM
pipe's Avatar
pipe
Some guy's use 0000 steel wool (super fine) and keep the window wet with your glass cleaner and rub lightly. Or www. eastwood.com and they sell a kit to polish your windows. It's a round felt pad that goes in your drill chuck then you wet it down and use their cleaning compound and it comes out crystal clear. Pipe
Old Jul 14, 2007 | 07:36 AM
Da Mail Man's Avatar
Da Mail Man
........i USED to have the problem on the front windshield that the wipers would not touch...i used bon-ami (or bar keepers friend) cleanser and one of those sponges with the slightly rough surface on the one side.......i wet the glass, applied the clenser, and used the rough side with a steady but rather hard down pressure and it worked fine.........i did try vinegar because the marks seem to be by hard water but, it did little if any.......after that, i applied rain-x......
Old Jul 14, 2007 | 01:37 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Try a clay bar with some spray detailer as a lubricant.
Old Jul 14, 2007 | 01:41 PM
mtnman's Avatar
mtnman
St. Jude Donor '17-'18
This is what body shops use to get overspray off of glass as well (super fine steel wool , that is)
Old Jul 14, 2007 | 01:55 PM
newbecorvetteguy's Avatar
newbecorvetteguy
My son found a product packaged and sold in my area called 'Stain Bully'. It would be found in the same section as Tile-X and the like in stores. Takes water spots off glass in seconds flat leaving it looking like brand new. Don't know if it's harmful to paint or not. Haven't conducted that experiment yet, but it sure works on glass.
The active ingredient appears to be something called ammonium bifluoride. Don't know how nasty the stuff is but I'd sure recommend wearing chemical resistant gloves and work up wind while using it. Something that works this well can't be good for you.
To Water Spots
