LT4 engine picture needed
Old Aug 1, 2007 | 07:09 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Default LT4 engine picture needed
Specific picture needed. I need the passenger side fuel rail area.
Basically, take off the fuel rail cover on the passenger side, and I need a picture of what's underneath. I think I am still missing part of the vaccuum setup near the throttle body.
Any help is greatly appreciated!
Old Aug 1, 2007 | 08:45 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
If nobody else comes through with one today, I can get you one late this afternoon when I get home from work.
Old Aug 1, 2007 | 08:51 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
Would be greatly appreciated.
Old Aug 1, 2007 | 12:48 PM
RollaMo-LT4
I went home for lunch, so snapped these for you then.
If you need a different angle or something specific, just let me know and I'll do what I can.
Old Aug 1, 2007 | 12:55 PM
Andrew's Avatar
Andrew
Wow that motor is clean!! I expected it to be very dusty under there. Do you take off all of the plastic garbage when you clean your motor and how do you get it that clean? I need some pointers!
Not trying to hijack the thread, just amazed!!
Old Aug 1, 2007 | 01:18 PM
Warp8's Avatar
Warp8
"plastic garbage"???????
Old Aug 1, 2007 | 02:01 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
That's perfect, and it answers my question too! Thank you!!
I took a picture of mine, and that little plug doesn't seem to go any where...see my pic...I was worried that I was missing a vaccuum hookup. I did find that one of the injector clips was loose too. Still chasing ghosts....
Thank you my friend!!!!!
Old Aug 1, 2007 | 02:14 PM
RollaMo-LT4
Your welcome
Old Aug 1, 2007 | 03:16 PM
Andrew's Avatar
Andrew
Warp8,
I didn't mean for that to be offensive, I was trying to describing all of the plastic cladding that covers up the injectors and fuel system. It makes the engine look clean, but really does not serve any other purpose.
96LT4,
I saw Rolla's pictures and notice that piece as well. It made me go out at lunch and check to see if my car is that way. It is, that makes 3 that are plumbed that way.
Old Aug 1, 2007 | 03:58 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
I went and looked at a CE LT4 at lunch, and that little plug wasn't there....
Old Aug 1, 2007 | 04:05 PM
aquablue96's Avatar
aquablue96
How do you get a motor that clean?
Old Aug 1, 2007 | 04:52 PM
Andrew's Avatar
Andrew
Maybe a mid year production change. Curious??? Do you have VIN that is early or late for each car?
Old Aug 1, 2007 | 05:22 PM
Mrs. glass car's Avatar
Mrs. glass car
Hey RollaMo-LT-4... don't you ever clean that thing?
Impressed to say the least!
Old Aug 1, 2007 | 05:40 PM
RollaMo-LT4
I am not real sure exactly what your asking about?
Old Aug 1, 2007 | 05:44 PM
RollaMo-LT4
At the risk of making some people faint, I do wash it. I am just careful and not get too much water around the opti. Also 2 or 3 rolls of paper towels and Simple Green. Be careful with the simple green on the underside of the hood though. It can leave a chalky white residue.
Old Aug 1, 2007 | 06:08 PM
Andrew's Avatar
Andrew
That's what I thought and my car does have this as well. Not sure what it is for or if it was changed mid year or not.
Old Aug 1, 2007 | 06:11 PM
aquablue96's Avatar
aquablue96
I have vaguely heard about water and the opti. Can you explain more what the problem is with this combination? And where exactly is the opti and what does it look like so I can avoid it
To LT4 engine picture needed
Old Aug 1, 2007 | 06:17 PM
Andrew's Avatar
Andrew
The opti is located below the water pump on the front of the block. It is slightly off center toward the passenger side. If you follow the spark plug wires, you'll find it. Looks like a narrow, flat distributor. Not the best electrical design GM ever came up with!
Old Aug 1, 2007 | 08:41 PM
RedGS's Avatar
RedGS
This got me curious so i just went out to the garage and took a peak under mine and it doesnt have that tube. Mines also an lt4.
Old Aug 2, 2007 | 06:53 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
That's what I was asking about. It doesn't seem to go anywhere, but it's hollow.
