Starting problem
Old Aug 28, 2007 | 04:25 PM
dboldt's Avatar
dboldt
Default Starting problem
I have an 89 with automatic trans. Occasionally when I turn the key to engage the starter I get nothing. The dash lights and accessories work but the starter will not engage. The problem is intermittent. The car can be cold or hot. There's no pattern of when it will start and when it won't. Anyone have any experience with this issue? I've had the car in the shop but they couldn't find the problem
Old Aug 28, 2007 | 04:58 PM
Square's Avatar
Square
The 2 things I know of that will cause that are:
1)Bad starter/solenoid
2)Corroded battery cables
There may be many other reasons, but those are the 2 I have seen.
Old Aug 28, 2007 | 05:08 PM
jabez's Avatar
jabez
I will say the usual....VATS
Old Aug 28, 2007 | 05:10 PM
Goldcylon's Avatar
Goldcylon
Make sure the shifter is all the way in park. Maybe the neutral safety switch. Put you foot on the brake pull back the shifter and put it back into park. Then try to start since there is no hot or cold pattern. Just another possibility
Old Aug 28, 2007 | 05:15 PM
dboldt's Avatar
dboldt
I've checked the battery cables and other connections. everything looks brand new, no corrosion at all. I'll have the mechanic check the starter. The challenge is the problem is intermittent, very frustrating. Thanks for the reply.
Old Aug 28, 2007 | 05:30 PM
shadowman1's Avatar
shadowman1
Old Aug 29, 2007 | 09:32 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Has a code 46 been stored in the ECM ??
http://members.shaw.ca/corvette86/Code%2046.pdf
Old Aug 29, 2007 | 11:24 AM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Do this first: clean off any crud accumulated on the chip embedded in the keys.
Old Aug 29, 2007 | 12:43 PM
jfb's Avatar
jfb
When it won't start, that is when you should do some diagnostics. Your mechanic will never find anything if it cranks ok. Jump the gear selector switch (at the base of the gear shift lever) and try a crank. If no crank, jump 12v to the jumper, the starter should crank proving the starter is ok. If the starter proves ok, and the key won't crank it, then you probably need a new ign lock which will have new contacts that make connection to the pellet. You can also pull the hush panel above the drivers feet and find the 2 wires from above the steering column that go to a 2 pin connector and unplug it. Insert your key and measure the resistance across the wires from the steering column. It should measure the same resistance as the pellet. If more than 4% from the assigned resistor value or over 13k ohms, you need a new ign lock.
To Starting problem
