Great, thanks for the info... I'll do a search on Viper and see what I can find.
This might help the model number for the keyless entry system id is Viper Model 211HV. I added a rear hatch release solenoid that works when you hit the aux button.
I have a keyfob for the 91 with 4 buttons.
Lock, unlock, trunk, and a * on it.
Horn beeps once when you unlock and twice when you lock, lights flash also.
It has TRC initials on the fob.
It came with the car so I dont know much about it.
It was an add on from a previous owner. Again GM didnt have PKE until 93. My viper keyless entry system has the same functions with four buttons but one is a panic button.
I installed a GM VKE 1000 on my 88 coupe, gives you GM transmitters and three channels plus panic. Lock/unlock, hatch and an extra for whatever. Works and looks factory.
Get a bulldog KE1702, about $35.00 from Amazon, and easy to install, good luck Jim
I love mine too. It was very easy to install. If you want the hatch to pop, the lights to flash, or the horn to honk, you will need to order extra relays.(they're cheap$$) run a search, there are a lot of threads on this.
