Ignition Timing
Old Sep 24, 2007 | 08:56 PM
Bill Cude's Avatar
Bill Cude
Default Ignition Timing
Quick question, I'm going to check my timing tomorrow, if I have to make adjustments, I know you have to put the system in bypass. Can anyone tell me how to put in bypass ? Oh by the way it's a 1989 coupe.
Old Sep 24, 2007 | 09:52 PM
Greg0u812's Avatar
Greg0u812
should be a connector to the right of the distributor (possibly taped to a harness) with a tan/black stripe wire on one side and a pink (I think) wire out of the other side. this is the one to disconnect. I just finished washing my hands from doing the same thing (mine included wires,plugs, cap..........etc, etc, etc........). Good luck with it.
Also, once you are done and get it connected back together.......you will have a code to be cleared.
Old Sep 25, 2007 | 09:48 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My EST bypass connector is beside my brake booster. Just unplug it to check and adjust timing. When finished, plug it back together and remove neg battery cable for a few seconds, to clear the code.
Old Sep 25, 2007 | 10:50 AM
Muffin's Avatar
Muffin
Not to flog a dead horse, but Greg and Agent86 are both correct. Disconnect is between the booster and the distributor. There should be a similar connector on the other side of the booster that when disconnected will clear codes.
Old Sep 25, 2007 | 12:51 PM
Greg0u812's Avatar
Greg0u812
Hey Muffin......
Know what the color of the wires on that connector are?
I assume this should be done with key turned off/out of ignition?
How long should it be disconnected?
I would rather do it this way than lose the radio presets.
Good info for all!
Old Sep 25, 2007 | 02:29 PM
Steel Blue 91's Avatar
Steel Blue 91
Frm the Tech Tips section:
https://www.corvetteforum.com/techti...=276&TopicID=5
Kind of long, but worth it.
Old Sep 25, 2007 | 06:06 PM
Da Mail Man's Avatar
Da Mail Man
....yup.....
To Ignition Timing
