headlamp replacement
Old Nov 21, 2007 | 11:29 AM
takovr's Avatar
takovr
Default headlamp replacement
My head lamp burned out on my 1986 corvette, Need to replace it. Anyone know what is the best one to get and how hard is it to replace them?
Old Nov 21, 2007 | 11:54 AM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
1. It depends. Many people like Silverstars, like I do, many like Hella via conversions. Different strokes for different folks.
2. Very easy. Use the search function for specifics. It involves rotating the headlight a certain way, removing the headlight cover, and then the ring bracket.
Here's a tip: use the Search Function, use it well. There's a whole bushel of useful info archived away that most, if not all questions will be answered.
Good luck!
Old Nov 21, 2007 | 12:01 PM
takovr's Avatar
takovr
Default thank you for te help
thx for the help, I do have a service manual it says to remove 4 screws.
I guess there the ones for the head light cover.
Old Nov 21, 2007 | 01:29 PM
hardlight's Avatar
hardlight
Berry easy, get some Hella lenses for a great pattern and some high power PIAA bulbs and enjoy the night.
Old Nov 21, 2007 | 02:11 PM
DougSilver's Avatar
DougSilver
When removing the plastic body-colored headlight trim cover (or whatever it is called), make sure you have a hand or something underneath when removing the screws to keep this piece from falling and scratching.
Doug
Old Nov 21, 2007 | 02:44 PM
bd2626's Avatar
bd2626
I used plastic replacements from NAPA to help reduce the weight on the assembly. My old eyes couldn't tell the difference is brightness from others.
Old Nov 21, 2007 | 03:40 PM
takovr's Avatar
takovr
Default plastic replacements?
Can you tell me what you mean about plastic replacements ?
Old Nov 21, 2007 | 08:37 PM
vetteboy88's Avatar
vetteboy88
I did this (plastic lens thing) with mine also. Less weight has saved the motor, I'm sure!!! The glass lenses are very heavy.
Old Nov 21, 2007 | 09:16 PM
Gary R's Avatar
Gary R
I installed Silverstars and really couldn't tell much difference. I decided that I probably should check the adjustment and then I noticed a big difference. I'm not sure how much the Silverstars helped but I'm satisfied with the lights now. Others on the Forum have reported good improvemnet with the Silverstars. Gary
Old Nov 21, 2007 | 11:42 PM
CE1's Avatar
CE1
I believe they have come out with a Silver Star upgrade now...
To headlamp replacement
